Irradic idle when warm...02 sensor?
I picked up a 91 4x4 22re truck it runs great when cold but when warmed up its idle wanders up n down drastically. Upon cheking it out I found the 02 connector not connected to anything and can't find the connector it goes to? I'v tried tracing it from the ECU but not sure which one it is?
on a 91, the O2 sensor should be under the cab in front of the catalytic converter... there may also be a 2nd one behind the converter. if you have one on the exhaust manifold, someone may have replaced the manifold with an earlier model one that has the sensor there, and left the sensor in to keep the hole plugged.
so, check under the cab and see what you have.
Blamalam
Mar 12, 2022 07:34 AM
montanatruck
Feb 26, 2017 07:07 AM
