Ozarks Ozarks Chapter
22RE issue
Old Nov 13, 2008 | 11:27 AM
ADH8796's Avatar
22RE issue
It seems my second cylinder isn't firing. I have a lot of exhaust noise when accelerating. But here's the weird part the other day I went for a 45 min drive and just like that the secon d cylinder started firing and wow what a difference it made. Ran great all day long after that but when I got home and let it sit overnight my problem came right back. Any idea's?
Old Nov 13, 2008 | 01:02 PM
Cargun's Avatar
Watch it idle at night, it's better than the 4th of July. Cory's spark plug wire routing leaves something to be desired
Old Nov 16, 2008 | 01:35 PM
colsoncj's Avatar
I think what hes trying to say is check for miss-firing due to sparkplug wires or bad plugs.
Old Nov 21, 2008 | 04:28 AM
ADH8796's Avatar
new plugs and wires so I know that's not the problem (I checked all of them to make sure)
Old Nov 21, 2008 | 06:15 AM
axman667794pickup's Avatar
you seen any oil leaks around the head gasket?
Old Nov 21, 2008 | 12:53 PM
ADH8796's Avatar
Nope not at all
Old Nov 21, 2008 | 01:50 PM
soarerjzz30's Avatar
Clogged injector??
Old Nov 22, 2008 | 12:52 PM
ADH8796's Avatar
Nope I checked that too and still no luck
Old Nov 22, 2008 | 01:03 PM
olharleyman's Avatar
fouled plug? even new they can be bad ya know I just had this happen with my 3.no and thats what the issue was , brand new Nippion Denso plugs even
Old Nov 23, 2008 | 01:30 PM
ADH8796's Avatar
Nope all the plugs are good. Moved them around a few times and the second cylinder is the only thing not firing.
Old Nov 23, 2008 | 04:13 PM
colsoncj's Avatar
what about distributor cap and rotor?
Old Nov 23, 2008 | 05:20 PM
ADH8796's Avatar
Cap and rotor look good but I haven't replaced it or anything. I've pulled the plug wire on the 2nd cylinder while the engine is running and it apears to be working just fine.
Old Nov 23, 2008 | 09:17 PM
colsoncj's Avatar
how do you know the second cylinder isnt firing?
Old Nov 24, 2008 | 05:06 PM
ADH8796's Avatar
When I pull the plug on the second cylinder nothing changes at all.
Old Nov 24, 2008 | 09:52 PM
colsoncj's Avatar
ok, leave the plug attached to the ignition wire, ground the plug on the valve cover gasket and start the motor. then see if the plug itself is firing, lemme know what you find.
Old Nov 25, 2008 | 04:46 AM
waskillywabbit's Avatar
Toyota or aftermarket plug wires?
Some of that cheap aftermarket Toyota stuf is just that...cheap crap.
Had a buddy with the exact same problem and it was his new aftermarket plug wires.
Old Nov 25, 2008 | 03:44 PM
ADH8796's Avatar
Yes the plug is firing when grounded to he balve gasket. And it's clear that the cylinder is building plenty of compression (crazy loud). It seems like the only think that might make since is that fuel isn't getting into the cylinder. But I don't know?!?!
Old Nov 25, 2008 | 07:35 PM
colsoncj's Avatar
ya, you've got a fuel issue... check the connector on the fuel injector to make sure its securely on there... if it is, I'd say look into getting some injectors (I have a few lying around)
Old Nov 26, 2008 | 07:54 AM
ADH8796's Avatar
The connection is good. I moved the injector from cylinder 1 to cylinder 2 because I knew it was working in cylinder 1. Anyway it's not working in cylinder 2 so I'm thinking something is wrong with the wiring for cylinder 2 injector (it's not the actuall injector). But I'm not really sure where to start as far as finding the problem.
Old Nov 26, 2008 | 09:01 AM
colsoncj's Avatar
are you leaking fuel out around the injector or do you have any kind of gas smell, and is the injector properly seated?
I'd almost be tempted to pull the connector off of the injector and check it for voltage signals using a multimeter
