Please Help Will Not Idle When Between Hot And Cold
Old Aug 28, 2008 | 10:04 AM
NEALMG's Avatar
AFTER THE TRUCK (92 3VZE) HAS GOTTEN TO RUN TEMP AND THEN IS TURNED OFF FOR A WHILE (LIKE GOING INTO A STORE FOR A FEW MINUTES) IT DOESN'T WANT TO START AND WILL NOT IDLE WHEN IT DOES START. AFTER IT GETS BACK TO RUN TEMP OR WHEN COLD, EVERYTHING IS FINE.
Old Aug 28, 2008 | 11:20 AM
abecedarian's Avatar
If it hasn't been done in a while, the fuel filter may be getting plugged.
Then maybe check the coolant temp sensor for the ECU.
It sounds like the 'heat soak' that occurs when you shut a warm engine off may be pushing the temp sensor out of range.
the1998sr5
27
Nov 17, 2015 09:30 AM
Dennisx2
Aug 4, 2015 01:26 PM
tomczaksdiesel
Jul 26, 2015 10:35 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
ty1er
Jul 19, 2015 06:42 PM
