Vehicle Audio & Home Entertainment Discussions here pertain to vehicle stereo systems and home entertainment systems
No sound from stereo after install
Old Aug 3, 2008 | 06:21 PM
lanai's Avatar
Can someone help me. I have a 2002 4Runner.
I just removed my Nakamichi head unit and reinstalled my old stock unit. When I turned the unit on, I dont get any sound.
I remember the audio tech who installed the Nakamichi saying that he disabled and removed the stock amp.
When I reistalled the stock head, I also put the amp back in and plugged in the harnesses.
Did I miss a step because I'm not getting any sound. I can see that the stereo is on or when I insert a cd, I can see that it's being read.
I appreciate any help anyone can give me.
Alex
Old Aug 3, 2008 | 07:45 PM
olharleyman's Avatar
Alex
Check the amp fuses and make sure you have the outputs from the head unit into the correct inputs on the amp. Also check to make sure you have the output level turned up on the amp.
Old Aug 3, 2008 | 11:14 PM
RobD's Avatar
Odds are, it isn't getting power or it's not being grounded properly. The other option is that he rewired the speakers with leads that aren't linked back to your amp.
Old Aug 3, 2008 | 11:15 PM
DeathCougar's Avatar
Those things are externally grounded. You need to hook up the antenna, and make sure its screwed into the dash first, then you will get sound.
Old Aug 6, 2008 | 01:19 PM
lanai's Avatar
Thanks for your help. The problem was with the wire for the remove control.
Old Aug 6, 2008 | 01:58 PM
RobD's Avatar
I hate those remove controls.
jasonty
41
Dec 23, 2018 01:00 PM
montanatruck
Feb 26, 2017 07:07 AM
TDonkey
Jul 26, 2015 10:14 AM
kvanzandt1
Jul 18, 2015 10:15 AM
mlavery85
Jul 12, 2015 10:33 AM
