New wheels
New wheels
I bought some 16 inch wheels for my truck, they are Mickey Thompson Classic IIs and they are 10 inches wide. Im to broke to do any lifting now, is there a tire that i can fit on my stock 93 pickup that will be wide enough to hold the bead well enough.
I doubt it without some trimming. i mean a 11.5 at the max might have a 10" wide rim, but you would want at least 12.5 inch wide tire, which will rub and you would need to trim. good luck. someone else would know more that I though.
12.50's would be the best, however as already mentioned, they'll most likely rub, depending on the BS of the wheels.
8's are best for wheeling anyway. They'll hold a bead a ton better, when the tires are aired down, then the 10's will.
I've even run 12.50's on 7's before and they worked great.
Fred
Up&Down
Aug 5, 2015 06:20 AM
Luvmeye22re
Aug 4, 2015 03:53 PM
skoti89
Jul 6, 2015 07:45 PM
