1988 4x2 auto tranny
My great aunt gave me a 88 2wd pu with auth trans and I put a new radiator,hoses,belts,and thermostat but it wont shift into overdrive.Any suggestions on why its not shifting?Thanks
man i junked my 88 2wd A43D trans truck last april it always worked great hmm
i did notice thoguh that it wouldnt go into OD until it was at a certain temp
if it was too cold then it stayed out of OD automatically for a while no matter how fast i tried to get it up to
on warm days it always went right into OD at required speed somewhere around 40 miles per hour or so
temp sensor/ECM issue on yours maybe
if the bad solenoid is ruled out
or wiring plug connection corrosion or loose-ness, etc
if these solenoids use any rubber seal or any kind maybe some trans fluid seal conditioner additive may help ?
always is nice to put in higher mileage trannies before its too late and seals go bad due to age and heat
good luck
good luck
jasonty
41
Dec 23, 2018 01:00 PM
FS[PacSouthWest]: 1988 4runner $1500
4x4-runner
Aug 3, 2015 07:14 PM
