Front end shimmy in 4x4
Howdy folks - I've been lurking for a few months and picked up a lot of good info, but this is my first post.
I picked up a 1992 Toyota 4runner with 214,000 miles on it back in March. It's v6, 4x4, 5 speed, and runs pretty good though it needed some miscellaneous work when I bought it. (new windshield, new brakes all around, new hubs, got the rear speakers working, got the antenna working, got the drivers power window working right, new gas cap, new steering wheel cover, new floormats, and a few things remaining to be done) I don't drive it too much (it's a bad weather/off-road/camping beater for me) so I've only put about 1,000 miles on her.
It didn't have any hubs on it when I bought it (and obviously didn't have working 4x4, but the previous owner swore it worked just fine, but he had to take the hubs off for some unknown reason), so I picked up some Warn manual locking hubs. With the hubs in 4x2, the truck handles just fine at highway speeds. With the hubs in 4x4, whether 4x4 is active or not, she gets a pretty wicked shimmy from the front end beginning at about 40mph, pretty bad by about 50 and I've been too scared to go over 60. Any ideas what it could be?
I've seen some other threads that recommend checking the U-joints for play. This is the first time I've worked on a 4-wheel drive, so I'm a little new to the terminology. Are the U-joints what connect the front driveshaft from the tranny to the front diff? How do I check them for play? I got under the car and tried to move things around, but didn't find anything loose.
You need to remove the front driveshaft, then check the u-joints (you will see them, they look like universals joints for sockets) and if they dont move easy as pie its time for new ones.
YOur not supposed to be going 50mph + in 4wd anyways, I surely hope its on dirt roads too. Pavement and 4x4 = no!
This isn't a huge deal because I can always get out and manually switch the hubs before I engage the 4x4 shifter, but sometimes it's nice to have the "shift on the fly" capability that locking the hubs in 4x4 gives.
toyoda8488
Jul 5, 2015 10:18 PM
