Rebuild of 3vza but what sizes?
Old Jun 21, 2008 | 02:41 PM
Printerstu's Avatar
Hi ive done a pull down of my 3vze and about to order the rebuild kit but need the sizes of bearings and rings. Hopefully someone can help me with this as the bearings dont have any info on them apart from a code. Ill put the part, stamp code then my measured size. If someone can tell me if i need std or oversized that would me greatly appreciated. thanks in advance.
Piston - Skirt size = 87.26mm
Crank Main bearing - Stamp= 35021 - Measured Size = 63.88mm
Crank Rod Bearing - Stamp= D3FA - Measured Size = 54.95
Other stamps
On the Crank shaft in the middle says F1111
On the top of the block next to each bore is number 2
Each piston says 2 on it
Under the block on the little tab says 222
232
Hope someone can help with this info
thanks in advance
Stuee
Old Jun 21, 2008 | 03:22 PM
TOYOTA 1's Avatar
you need to check your crank with a dial indicator to see if you need it ground.. if its a stock motor then the bearings and pistons/rings are standard size..
Old Jun 21, 2008 | 03:37 PM
thook's Avatar
Are those "measured size" what you measured? Or, are they referenced from a manual? If they're your measurements, how did you measure them? Plastigage?
Old Jun 21, 2008 | 07:14 PM
Printerstu's Avatar
Hi mate,
This was the crank measured using metal digital verneer calipers.
thanks
justdifferentials
Just Differentials
14
Sep 24, 2017 08:32 PM
justdifferentials
Just Differentials
Aug 30, 2015 08:42 PM
justdifferentials
Just Differentials
Aug 15, 2015 05:25 PM
Gravel Maker
RuffStuff
Aug 6, 2015 04:27 PM
Gravel Maker
RuffStuff
Jul 27, 2015 06:53 PM
