how loud do your valves tick on 22re?
i adjusted my valves to spec but they seem a little loud. i bought the truck non-running so i have no baseline to start from. dosent sound horrible just a bit loud. is that normal? im going to re-adjust them after 100mi. or so
I'm sure one of the experts here will chime in, but I would lean towards a little loud vs. not loud. Or, to say another way, I would rather have the valves set a little on the loose vs. a little too tight. If they are too tight, which I would think would be a little quieter, they would hang open a little, which would lead to burning your valves.
Just my thoughts, whether right or wrong!!!
vmax84
vmax84
Did you adjust them cold or warm and what settings did you use?
I adjusted mine (cold) when I rebuilt the engine a few weeks ago. They were noisy. I drove it like that for about 600 miles and then adjusted them "warm" this past Friday. The noise has totally gone away. I used .008 intake and .011 exhaust. I think the FSM says .012 for the exhaust.
X's 2 on the valve cover bolts; seen it twice now on the 22re; not on my truck, but friend's trucks
that's easy to check though; just losing the bolts while the trucks running. if it goes away, they were to tight...
montanatruck
Feb 26, 2017 07:07 AM
Sep 4, 2015 09:27 AM
