Can I swap my stock front 4.10 diff with a stock 4.56?
Old May 14, 2008 | 07:55 PM
Mojo_Risin's Avatar
On a v6 4Runner with stock 4.10 gears - can I swap a front carrier (differential) with a stock diff with 4.56's? Did the make V6 4runners wth stock fron 4.56? Or was it only 4 cylinders? And if so will that still work for a complete swap out?
Thanks
John
Old May 14, 2008 | 08:03 PM
bigt's Avatar
yup 6 cly have 4 pinon gears not 2 and are a little beefyer but both can be interchanged
Old May 14, 2008 | 08:09 PM
Mojo_Risin's Avatar
So they did make v6 4runners stock with front 4.56's? There are a few front ifs diffs at local salvage yards that say they are 4.56 but I'm leery that they know what they are talking about. If I went an looked at the diff how can i confirm the gear ratio and if it was from a v6 or 4cyl.? And do i have to worry any of those might not have the ADD?
Thanks
John
Old May 14, 2008 | 08:18 PM
bigt's Avatar
actually i dont know if they did make v6 with a 4.56.. iof in doubt count teeeth ... might wanna wait till someone eles chimes in.. its late and i might not be thinking right lol
Old May 14, 2008 | 08:34 PM
DeathCougar's Avatar
If you are talking 3rd gens....
The 4.56 was RARE. Used only in 4cyl, unless special ordered IIRC.
If you swap the front diff, you will have to swap the rear as well.
Old May 14, 2008 | 08:50 PM
Mojo_Risin's Avatar
I do know that much - but not much more
So if what you are saying is correct - then the local slavage yards that list the diff coming from a 3rd gen 4runner 3.4 L V6 with 4.56's - are probably worng. But if they are listing them as coming from a 4 cylender - it could possibly have 4.56's - correct?
Any reason I wouldn't want a 4cyl front dif in my v6?
John
Old May 14, 2008 | 09:01 PM
crolison's Avatar
4cylinder front diff= same as v6, you will be fine. the rear diffs are different, and thats all.
Old May 15, 2008 | 06:41 AM
Mojo_Risin's Avatar
EDIT- never mind answered my on question.
John
Old May 15, 2008 | 08:34 PM
Mojo_Risin's Avatar
What about a front diff from a 96+ 4cylinder Tacoma? Any reason that shouldn't work if it's ADD?
John
Old May 15, 2008 | 09:33 PM
tacomas and 4runners use the exact same diff, 96-00. I 2001, the front diffs changed from vacuum actuated to electric acctuated.
Old May 16, 2008 | 07:25 AM
Texas_Ace's Avatar
Along these same lines, i have (at least the diff code says i do) 4.91 gears on mine. I want to get an e-locker but i don't want to drop my gearing either.
Can i swap my stock gears with an elocker so i keep the stock Ratio but get the elocker?
And if so, got any cheap elockers sitting around?
Old May 16, 2008 | 08:09 AM
No you dont, Toyota never made a 4.91 gear ratio
Being that yours is a limited, therefore automatic, you should have the 4.30 ratio.
Old May 16, 2008 | 08:45 AM
Mojo_Risin's Avatar
texas Ace - If you have 4.30's (which is pretty common) you can easily find a used 4.30 geared elocker third member. But hopefully you're aware it's not a straight swap if you don't already have the locker - you'll have to modify your axle housing.
go to http://car-part.com/ and make sure you select CARRIER as the part you're looking for (not differential )- you will get more results that way. I see 4.30 e-lockers starting at $300.
John
Old May 16, 2008 | 10:24 AM
Texas_Ace's Avatar
I actually got the 4.91 number when i called YOUR shop lol.
Whoever i talked to asked what my vin number said and when i read it off he obiously was trying to figure it out and then said :it says it is a 4.91 gearing".
So do i trust you or do i trust you lol.
Old May 16, 2008 | 10:28 AM
Texas_Ace's Avatar
John
Yeah, i have looked into it and know there is more than just getting the elocker. Though i wish i could find a whole 3rd member and just make it easy and then i just have to wirre it.
Thanks for the link, i will take a look at that!
Old May 16, 2008 | 10:29 AM
They prolly told ya 3.91, not 4.91 ya ding dong lol
What is your axle code?
btw you sure you called Nix99? We dont go off the VIN, we go off the axle code on the drivers door
Old May 16, 2008 | 10:36 AM
Texas_Ace's Avatar
Yes, i called the number i saw you post a few times on here. And he did ask for the axle code, vin code, axle code, whatever! The CODE! lol
And yes i am sure i was told 4.91, i asked severl times, are you sure? and was told yes. I was surprised as i never knew toyota made 4.91. I was also told that toyota never made an elocked with those gears, which i thought would explain why i don't have one.
As for the code, just to stem any confusion here is a picture, look for yourself, maybe i told him the wrong code...
Old May 16, 2008 | 10:48 AM
Well thats odd....anyways, your axle code is A03A, which should be a 3.91
Toyota didn't use a 4.91. Must not have talked to me lolol
So, to clarify, A03A is a 3.91
And I am assuming you do not have the rear locker?
Old May 16, 2008 | 10:56 AM
Texas_Ace's Avatar
Ok, must have been some mis-comunication then lol.
And no, i don't have a rear locker. Though with seeing that my gears are that bad i might want to re-gear while i am doing this if i can't find a locker with those gears. Who knows, or i will just switch the gears over for now and re-gear later.
Old May 16, 2008 | 11:17 AM
Mojo_Risin's Avatar
That seems weird - according to this.... http://www.sonoransteel.com/Toyota_axle_codes.html
looking up your code you should probably have either 4.10 or 4.30 - but I don't know. The best think to do is go out and jack up one rear tire. mark the drive shaft and mark the tire. Spin the tire 1 revolution while counting how many times the drive shaft spins - less than 4 = 3.91 a touch over 4 = 4.10 or more like 4 1/4 turn = 4.30 etc. It's not 100% accurate but will easily tell you if its under 4 or over 4.
Also you can buy complete rear axle assemblies (with e-locker) off car-part.com too.
Just search for "rear axle assy" put in what you're looking for, etc...
John
