Hydrogen fuel cell for better gas mileage
Old May 13, 2008 | 02:33 PM
sharrack's Avatar
First off...............Is there any merit to this "do it yourself Hydrogen fuel cell
hybrid idea" ?
If so , has anyone attempted it with a runner?
Thanks ,kenny S>
Old May 13, 2008 | 02:37 PM
chadbobb's Avatar
you actually want to run the engine off hydrogen? Or do you want to do a real electric hydrogen fuel cell (no combustion)
If you can come up with a means to store it and a way to manufacture it then you probably are past the two biggest challenges if you just want to run the engine off of hydrogen.
This is a huge project
http://www.switch2hydrogen.com/
here united nuclear mentions some stuff - but its not a hydrogen fuel cell - it just combusts hydrogen into h20
Old May 13, 2008 | 02:41 PM
Ghostduck's Avatar
Do a search and you will find that there's another active thread talking about this same thing. Oh and someone is in the process of attempting to use hydrogen as a fuel supplement.
Old May 13, 2008 | 02:42 PM
sharrack's Avatar
There seems to be a few sites claiming that you can use water with electric from your car battery with a do it yourself approach to turn your vehicle into a hybrid.
40 % better gas mileage claims.
Old May 13, 2008 | 02:43 PM
chadbobb's Avatar
where is something about using hydrogen? I have seen the HHO assist thread, but not one on this.
Old May 13, 2008 | 02:47 PM
eric-the-red's Avatar
$7000 - $10,000 for the conversion
At least they give you a free t-shirt
Old May 13, 2008 | 02:48 PM
sharrack's Avatar
http://www.runyourcarwithwater.com/?hop=hambo
Check it out. Kenny S>
Old May 13, 2008 | 02:59 PM
Beware of claims from the people who are selling the product, I wouldn't believe any until I got some independent studies.
There is a lot of research into adding hydrogen to gas or diesel engines, and they have been getting increased efficiency, though not 40% more. The studies I've looked at are more like 15-25%. The problem is most of them are done on stationary engines using an outside source of hydrogen, not the tiny amounts that can be generated with a small electolysis unit on a vehicle.
Old May 13, 2008 | 03:01 PM
chadbobb's Avatar
if that is what your looking into just follow the two HHO threads....
Otherwise it's a huge project if you want this to actually work.
Old May 13, 2008 | 04:11 PM
Flash319's Avatar
100% BS!! Buy a smaller car if you want to save money. The perpetual machine has not been invented yet...........
Old May 13, 2008 | 06:35 PM
CyMoN's Avatar
google stan meyer.
Old May 13, 2008 | 07:13 PM
PCE91V64x4's Avatar
If the OEMs are not using this product, beware. The OEMs would love to mass produce high MPG cars, the tech is just not there yet for fuel cells that cost under 6 figures, as well as electric cars and other alternative energy powertrains.
Old May 13, 2008 | 07:35 PM
abecedarian's Avatar
Where's my ZPE generator?
(zero point energy, for you that don't know)
Old Oct 6, 2008 | 01:26 AM
sweethe's Avatar
Have you ever heard of HHO fuel that has got to be the best way to save on gas prices.? Imagine the savings. It will cost you about $160, or two tanks of gas to install an HHO conversion kit
Hydrogen Car Kit - Save Money and Improve MPG Massively
Hydrogen car kit empowers your car to run on water and avoid oil as fuel. A vehicle however will not be able to run on water alone. There needs to be a mixture of gasoline and water to enable it to run smoothly.
Even the Water Fuel Conversion Kits - How Using Water As Fuel Helps Cut Your Gas Consumption Recently,there is increased awareness among many drivers of a technology that uses plain water tosupplement the cars' gasoline consumption. Called a water fuel conversion kit, it is a simpleadd-on to your current car engine that uses your car battery to carry out an electrolysis on water to produce Hydroxy gas (HHO). This Hydroxy gas is used to supplement
the burning ofgasoline in the car's engine.
Hydrogen generator kit for car can be better than gasoline or oil additives to raise gas mileage. When you make or do it on your own, you can save money on gas but will save lots of dollars on the kit and reproduce the system for other automobiles on your own.
Old Oct 6, 2008 | 05:19 AM
fasthorse67's Avatar
I'm quessing you work for, or are somehow affiliated with one of these companies. If it works how come fleet vehicles don't use it? Such as cities, post office, cops? It's all a big scam.
Old Oct 6, 2008 | 06:16 AM
khoopes's Avatar
Its interesting to see how different people react to technology. You have to understand that even if a car running on water is feasible the OEM's are not necessarily going to just jump on it. If all cars suddenly used no gasoline what would happen to the oil industry? Oil is a huge business and they have their influences on the auto industry, I would suspect.
The other things is every technology has problems. Look at internal combustion engines in general - they waste a huge amount of energy in excess heat. If your car runs off of water, how do you keep your fuel from freezing? Maybe that's not an issue in San Francisco but in Fairbanks its a huge problem. The other thing is pure water is hard to come by, and how are all of those mineral contaminants going to affect your hydrogen engine?
I know almost nothing about the tech here but you have to understand that every problem is multifaceted and it takes many years for the general acceptance of even a simple tech upgrade like going to CD's from Cassettes. The widespread availability of technical and operational support for a water fuel engine is probably not in place, and just dumping thousands of them into the comsumer base without good support is not sensible. Conversely, putting in the support without a large number of engines out there doesn't make investment sense either.... You get the point I hope.
Old Oct 6, 2008 | 08:42 AM
elripster's Avatar
Please provide the physics, governing equations, and energy balance behind this. Oh, and independent drive cycle analysis wouldn't hurt.
Until you can produce this, the claims are empty and meaningless.
Frank
Old Oct 6, 2008 | 08:52 AM
slisdexia's Avatar
I wonder how well this works, I mean water breaks up to hydrogen and oxygen. Both extremely combustable. I'd think adding it to your combustion process would be similar to nitrous i.e. into the air intake or plenum. As far as the freezing thing I think you are supposed to add some glycerin if I'm not mistaken. I've been thinking about doing this too, part as experiment, part financial, part messing around with my truck. Just dunno where to plumb the stuff in? Down the carb throat, before the filter? Post carb?
Old Oct 6, 2008 | 09:05 AM
elripster's Avatar
http://www.straightdope.com/columns/...ake-browns-gas
This pretty much sums it up in layman's terms are far as the physics issues is concerned.
I haven't seen one claim backed up with dyno verified drive cycle testing. Setting up a controlled test environment is not hard or expensive. Some data logging equipment is required as is interfacing with the vehicle's CAN network to see how much fuel it is injecting. Or, you could weigh the gas tank. This testing is done on every vehicle model sold. The reason it isn't done here is because it will debunk the claim of better fuel efficiency.
Frank
Old Oct 6, 2008 | 11:44 AM
Matt16's Avatar
Alright, I think you guys are throwing the baby out with the bath water.
As I understand it, the "HHO assist" is injecting hydrogen and oxygen into the intake. In the combustion chamber, the "HHO" ignites nearly instantly when the spark occurs and assists the fuel/ air mixture to ignite quicker. The theory makes sense to me.
[youtube]http://www.youtube.com/watch?v=jHSYy5zPfrQ[/youtube]
