82 pick up
82 pick up
thinkin about buyin an '82 pick up for $500
ad reads "this 1982 toyota pickup is anything but perty,but it runs good, good gas milage and a/c works,it has a 20R motor with a 5 speed transmission, also has a webber carb.and good tires."
advice? what to look for, good, bad, what parts last and what dont on this truck?
http://i26.photobucket.com/albums/c1...mesdior/82.jpg
thanks.
thanks.
#1 Double check the frame for rust and holes
#2 Check the 4 cab mounts inside for rust. Both floorboards and the mount in the rear corners. Peel the carpet up if it has it.
Then if thats all good anything else is fixable and you should have a solid truck.
choppe777
May 16, 2016 08:00 AM
LotOMiles
Sep 14, 2015 11:45 PM
mirabile4runner
Sep 3, 2015 07:15 AM
