3.0 egr removal write up
I just noticed a post for this on the 22re and I just did it for my 3.0. Since I started getting the 71 code. Ive got pics of everything and was wondering if anyone wanted a step by step write up it took me about 1 hour to remove it make the block offs and put em on and it took only a socket set, a dremel (or hacksaw if no dremel), some sheet metal, tin snips and some RTV gasket material. I have just the pics up now at http://www.angelfire.com/fl4/dmb
Let me know and I will write up the text shouldnt take long. I was hesitant about posting this cause it is illegal in most states but im in Fl and we have no emissions, plus it actually runs better now. Let me know.
To bypass the code 71 put a 10k resister in the EGR temp sender. It will trick the sender into thinking the egr is still working.
I would like to see a good picture by picture write up. Although I would prefer one that is not permanent since I need to smog my truck once a year.
wow that was fast. Im writing it upnow but if you go here http://www.angelfire.com/fl4/dmb you can see some of the pics the way i did it you cant put it back on cause I cut the pipe that goes into the intake to use the stock flange b/c i had a vacuum leak without it. anyway should be done tonight.
Also the 10 k resistor pushed into the harness will stop the code for the temp sensor but if the valve itself is broken that may not solve the problem and the truck will run rough
ok guys it is up in a rough form check it out and let me know what I can do to make it better here is the link again
I dont think it makes a big difference but that is what ive heard from others before doing mine. I just think it looks better, and its cheaper and easier to work with, my snips wont cut anything much bigger than 1/16". You have to work with what you got
Nice job! Did the same thing, almost step by step, a several weeks ago. I put up step by step instructions along with pic's and got a lot of greta feedback....and some very negative hardcore tree-hugging feedback. Opinions are like a-holes...everyone's got one!
I tried sheet metal at first and founf out that it gave too much of a leak so, I used 1/4" aluminum and grinded down the edges to make a perfect match to the gasket. That allowed me to not have to cut anything in case I ever decided to go back to normal.
How do you like the difference?
My truck seems to idle and run more smoother but, haven't really seen better mpg's. Have you?
I havent had it off long enough to calculate my mpg's with any accuracy but it does seem to idle better but I think I am getting too much fuel at idle I can smell it coming from the exhaust(but maybe this is just the hydrocarbons?). I wonder if this has anything to do with the temp? From what I understand the recirculating exhaust gas helps keep engine temps down(because it is inert and resists combustion ie. nitrogen) maybe i just need to run it and let the ECM adapt(as much as it can) . But when I hit the gas it does respond a little quicker. Other than that no noticeable changes yet.
Esibnitsud
Jul 30, 2015 08:19 PM
crashburnoveride
Jul 10, 2015 06:39 AM
