94 22RE knocks when I let up on accelerator
Old Mar 24, 2008 | 04:12 PM
ahickman's Avatar
I have a 94 22RE that has a knock when I let up on the accelerator during warm up. When the engine comes up to operating temps (5 minutes), the knock goes away almost completely. I read through a bunch of related posts, but can't differentiate between piston slap, worn bearings, wrist pins, or valve noise. Anyone suggest what this noise is most likely from?
Old Mar 24, 2008 | 04:48 PM
SEAIRESCUE's Avatar
In first 5 minutes, piston warms first. So, sounds like wrist pin or excess piston to wall clearance. You can figure out which cylinder it is by pulling the plug wires one at a time and cranking the engine. Get a second person to help. If its excess piston to wall clearance, drive it. You will be dead before it becomes a serious problem.
My $0.02
Old Mar 24, 2008 | 05:53 PM
thook's Avatar
Have you checked the timing? And, are you sure what you're hearing is an actual knock? Pinpoint where the noise is coming from, if you can.
Old Mar 24, 2008 | 06:37 PM
ahickman's Avatar
Timing is right on. I have gone so far as to advance/retard timing a bit to see if the noise goes away. It changes it a bit, but still present. I will get someone else to dip the throttle while I listen closely above and below.
Old Mar 24, 2008 | 07:12 PM
bigarms23's Avatar
check the valves
Old Mar 24, 2008 | 07:16 PM
ahickman's Avatar
Other than .008 intake and .012 exhaust, what would I look for?
Old Mar 26, 2008 | 12:17 PM
DaveInDenver's Avatar
Do you have a stick shift and does it happen only in certain gears? Thinking it could also be tranny noise, like a bad synchro, worn gears. I only mention it because I have a similar noise and I'm pretty sure it's not a worn wrist pin or out-of-round bore because I just built my new engine last year and the whole short block is only 8,000 miles old.
Tacoma1313
Aug 17, 2015 05:44 PM
RBK
Aug 2, 2015 11:33 AM
jake_v
Jul 22, 2015 03:17 PM
smiley52
Jul 11, 2015 05:16 AM
88runnergomas
Jul 9, 2015 01:12 PM
