Ozarks Ozarks Chapter
79-88 parts for sale
Old Mar 9, 2008 | 06:15 PM
colsoncj's Avatar
Parts for SALE!!!
Updated List 8/3/08
Description Quantity Price
4 cyl single intake tube 3 $3.00
4 cyl double intake tube 2 $3.00
Carb air cleaners 2 $5.00
V6 AFM assembly 1 $20.00
4 cyl AFM assembly w/top 2 $10.00
4 cyl AFM assembly w/ top and side hose 1 $10.00
4 cyl AFM 2 $5.00
4 cyl airbox top w/o AFM 1 $2.00
4 cyl airbox bottom 1 $2.00
79-83? Combo washer fluid and radiator overflow boxes w/ pumps 3 $5.00
84-88 Washer fluid container w/ pump 1 $3.00
84-88 Radiator overflow container 2 $3.00
Carb 1 $20.00
79-83 windshield wiper motors 3 $5.00
84-88 windshield wiper motors 3 $5.00
unknown windshield wiper motor 1 $5.00
79-83 brake master cylinder and booster 1 $10.00
84-88 brake master cylinder and booster 1 $10.00
clutch master cylinder 1 $10.00
84-88 power steering pump, bracket, and resevior 1 $20.00
84-88 4cyl plastic radiator fan shrouds 6 $2.00
4 cyl metal radiator fan shrouds 2 $5.00
84-88 4cyl radiator fans with clutches 8 $2.00
84-88 4cyl radiator fans without clutches 3 $1.00
V6 radiator fans with clutches 2 $5.00
84-88 Heater core assemblies 3 $10.00
84-88 Blower motor assemblies 4 $5.00
84-88 A/C evaporator assemblies w/ wiring 2 $15.00
Large blower motor assembly 1 $5.00
84-88 Blower motors with squirrel cages 2 $3.00
Small blower motors with squirrel cages 3 $3.00
A/C accumulator 1 $5.00
84-88 Drivers door, red, w/ glass and hardware, no vent 1 $30.00
84-88 Pass door, grey, w/ glass and hardware, w/ vent 1 $30.00
79-83 Pass door, grey, w/ glass and hardware 1 $30.00
84-88 drivers side front fender w/ inner fender plastic 1 $30.00
L43 Transmission 1 $20.00
L45 or L50 Transmission (not sure) 1 $30.00
8" Pinion - 10 Tooth 3 $5.00
8" Pinion - 9 Tooth 1 $5.00
7.5" Pinion - 9 Tooth 1 $5.00
8" Ring Gear - 41 Tooth 2 $5.00
8" Ring Gear - 43 Tooth 1 $5.00
7.5" Ring Gear - 46 Tooth 1 $5.00
8" 4cyl Ring Gear Carrier - Bare 2 $5.00
8" 4cyl Ring Gear Carrier w/ 41 Tooth Ring Gear 1 $6.00
83 Front Solid Axle - Housing only 1 $40.00
83 Front Solid Axle - Housing, Knuckles, dust shields, hub/rotors 1 $75.00
Solid Axle Steering Arms 2 $2.00
Pair of IFS Spindles 1 $10.00
Pair of IFS Spindle/Hub/Rotor/Caliper/BallJoint Assemblies 1 $40.00
SA rear axle housing - bare 1 $15.00
V6 Caliper 1 $2.00
Pair of IFS rear axle shafts w/ backing plates and brakes 1 $40.00
8" 4cyl 3rd housings - bare 2 $5.00
84-88 Steering columns with steering wheels and keys 2 $20.00
G52 Transmission CORE 1 $50.00
22RE Engine Block 1 $25.00
Box of weatherstriping seals 1 $15.00
IFS front axle 3rds 3 $20.00
SD timing cover with oil pump 2 $10.00
TD timing cover with oil pump 1 $10.00
4 cyl exhaust manifolds with O2 sensor hole w/ O2 sensor and heat shield 2 $7.50
4 cyl exhaust manifolds with O2 sensor hole w/ heat shield w/o O2 sensor 1 $5.00
Driveshaft 56 1/8 1 $5.00
Driveshaft 48 3/8 1 $5.00
Driveshaft 47 3/4 1 $5.00
Driveshaft 44 3/4 1 $5.00
Driveshaft w/ carrier bearing, 23 5/8 2 $5.00
Driveshaft w/o flanges 40 1/2 2 $3.00
Driveshaft w/o flanges 26 3/4 1 $3.00
85-88 Distributors, Fuel injected 2 $3.00
Distributor, vacuum advance, carb? 1 $3.00
Speedometer cables 6 $2.00
E-brake cables (firewall portion) 2 $5.00
84-88 pickup fuel door 1 $2.00
Steering wheels 2 $5.00
4 cyl gear driven forward shift transfer cases 3 $25.00
W56 Transmissions - Unknown Conditions 3 $60.00
85 Front Axle complete to spindles w/ SA hub/rotors, IFS calipers 1 $175.00
Spare inner axle shafts for front SA 1 $40.00
CT20 Turbo, needs rebuilt 1 $20.00
84 Pickup Parts truck w/ G52, T-Case, Front SA, Buckets, Good Dash 1 $225.00
And some 84-88 pickup rear glass (sliding or not) for $10, some door glass for $5.
And some grilles 79-88 for $10 each.
I also have a bunch of EFI parts including sensors, wiring harness, injectors, intakes, etc... Let me know what you're looking for and I'll give you a price.
All parts are located in Monett, MO 65708, any questions, let me know.
Old Mar 10, 2008 | 07:01 AM
Cargun's Avatar
Passenger door glass for an 88? Maybe I just need the whole door. I can get glass up here for cheap, but rust free doors are non-existant.
If you're looking for parts in the Northeast, Cory knows a guy up that way with a few.
Old Mar 10, 2008 | 07:30 AM
colsoncj's Avatar
i got the whole door, and iirc its red. want me to set it aside with some glass? vent or not vent?
Old Mar 10, 2008 | 03:43 PM
Cargun's Avatar
Yeah... keep that door back. Problem is I could wreck the truck completely before I get down to pick it up. It has vent windows now, I don't care if the new door does or not.
I got the widget. PM me your paypal address. Worst part is... mine seems to have stopped leaking At least I get to wait for warmer weather before swapping.
Old Mar 10, 2008 | 07:31 PM
colsoncj's Avatar
will do, and glad you got it ok!
Old Mar 13, 2008 | 01:02 PM
redvette's Avatar
Is the L trans. in working order? Also do you have a rear view mirror for an 81? And the rear linkage for the parking brake?
Old Mar 13, 2008 | 01:55 PM
colsoncj's Avatar
L trans, have no idea. it shifts and spins.
rear view mirror, dont think so.
parking brake stuff, dont think so.
Old Mar 17, 2008 | 06:13 AM
Cargun's Avatar
Gary may have some parking brake stuff.
Old Mar 17, 2008 | 08:24 AM
Mr Priceless's Avatar
bell housing off the w56 shipped to 73028?
Old Mar 17, 2008 | 08:28 AM
colsoncj's Avatar
pm sent.
Old Mar 23, 2008 | 09:05 PM
Napoleon047's Avatar
any quantity discounts available on multiple items?
Old Mar 23, 2008 | 09:13 PM
Elton's Avatar
you wouldn't happen to have that trim piece thats for the climate control my freind has a 87 and ill give u $5 dollars
Old Mar 23, 2008 | 09:18 PM
ozziesironmanoffroad's Avatar
the w56.. thats the tranny for the 3.0, right? if its for the 22re, how much shipped to 91977?
Old Mar 24, 2008 | 05:11 AM
colsoncj's Avatar
possibly... what are you wanting?
No I dont, sorry!
Pretty sure it came out of a 22RE. UPS quick quote of 135 to ship, not packaged or crated. If you're interested I could get a more accurate quote sometime this week.
Old Mar 26, 2008 | 06:20 PM
I might be interested in the W56 and a throttle position sensor. I have an IFS CV shaft to trade + cash. How far north would you be willing to meet me? i.e Nevada?
Old Mar 26, 2008 | 07:30 PM
colsoncj's Avatar
Dont need the IFS CV (but would take one for cheap), but I am lookin for a good idler arm if ya got one, but would need it before weekend after next. Far as meetin ya... i might be able to, but it could be a week or two... gotta take care of the rig and some stuff around the house. I'm sure we can work something out! shoot me an email!
Old Jul 9, 2008 | 08:12 AM
colsoncj's Avatar
Parts list updated and prices slashed... need to get rid of this stuff.
Old Jul 19, 2008 | 01:44 PM
colsoncj's Avatar
updated list
Old Aug 3, 2008 | 06:34 PM
colsoncj's Avatar
updated list
Old Aug 21, 2008 | 08:11 PM
88yotarunner's Avatar
I would like the complete solid front axle. Give me a call 816-606-4035 ask for Jeff so we can set something up. Thanks.
