tire pressure BFG 275/16 AT
Old Mar 5, 2008 | 08:21 AM
jrock's Avatar
on my 98 runner(5250 lbs), im runnin bfgs 275/75/16 rated at max 65psi(3klbs). After doing some PSI calculations, the results show that I should be runnin around 30psi. This seems really low to me-and there is an obvious bulge now.
im thinkin 40 would be a little better...goin to try the credit card and wet tread pattern test.
any thoughts?
Old Mar 5, 2008 | 09:13 AM
edzo's Avatar
errr, 40 is fine.
Old Mar 5, 2008 | 09:16 AM
Gerdo's Avatar
I've been running 35 psi for this set and my last set (I got 70k miles out of them) of ATs. Good, even wear.
Old Mar 5, 2008 | 10:45 AM
jrock's Avatar
okey do kee!
Old Mar 5, 2008 | 03:34 PM
Fo-runna's Avatar
I run 30psi; but I have 285/75's on stock rims. If you chalk the tread you can check for an even footprint to make sure your not over inflating.
Old Mar 7, 2008 | 12:53 PM
J'S LTD 4RNR's Avatar
I just spoke to a representative at BFG about recommended tire pressure. My tires are also BFG Allterrain TA KO but the size is 265/75/16.
She ran the calcultions in her program, yada yada, and came up with a recommendation of 50psi (just the weight of the vehicle). The funny thing is that the previous person I spoke with there recommended 55psi
I think I will just set it to 45-50 psi and call it a day. I just don't want premature wear on my new tires.
Jun 1, 2021 01:51 PM
Sep 4, 2015 09:27 AM
defrag4
Jul 31, 2015 10:50 AM
calderp
Jul 27, 2015 09:58 AM
