coolant level question
Old Feb 21, 2008 | 01:03 PM
mkgarrison5's Avatar
hey guys i just had my tbelt, waterpump and thermstat replaced by a local shop (close family friend) and when i got the truck back i noticed the coolant level in the resevior was low so i filled it back up to full.. well i got off work today and the level was inbetween low and full. i got home (35 miles later) and the coolant level is back up to full. is this normal? or does the system need to be burped? thanks guys
Old Feb 21, 2008 | 01:11 PM
KdF's Avatar
KdF
It`s a pressure system. It will, as you mentioned, burp itself if needed. When it gets hot it keeps more fluid under pressure in the system and when it cools, it will equalize itself thru the cooling process and re-fill the holding tank.
All should be well.
Old Feb 21, 2008 | 01:40 PM
GOH10 Runner's Avatar
check the level when it is cold, that shows the real level as the radiator dumps coolant into the tank when its hot.
Old Feb 21, 2008 | 03:20 PM
thanks guys
Old Feb 22, 2008 | 03:04 AM
MTL_4runner's Avatar
The fluid will expand and contract (hot/cold) so give it a few days to see if you need to add more.
Old Feb 22, 2008 | 03:47 AM
yeah thats what i plan on doing jamie.
has anyone noticed a better response throttle wise since having a t-belt change? call me weird lol. but with a 105k miles on the tbelt to a new one, i can tell a difference.. side question, do you guys reset the computer after a tbelt change?
the1998sr5
15
Jul 14, 2020 08:35 PM
itzmywife's
Jul 25, 2015 04:55 PM
akaphilly
Jul 9, 2015 02:18 PM
Avenged
Jul 9, 2015 07:55 AM
