Need help wiring new stereo. Keep blowing 15 ACC fuse.
Old Jan 6, 2008 | 09:53 PM
osker fenix's Avatar
Ok so im trying to install my sony deck and purchased a wiring harness, got that all setup wired everything turned it on and it worked fine for like 5 min. then stopped. Turns out it blew the 15 ACC fuse under the steering wheel. I thought maybe... i dunno...so i put a replacement 15 in there turned the key to ACC and immediately heard it POP. (now im out of fuses).
So im thinking i didnt wire it correctly. Every wire in the harness is spliced into the corresponding colors of the new stereo wires.....except there were two orange wires in the wire harness an orange/black=illumination and an orange/white=dimmer that did not have matching wires in the new stereo, so what i did is just left the orange/white wire alone and then spliced the orange/black in with the red=12V ignition wire. Im not a stereo expert, so if anyone can steer me in the right direction it would be awesome. NEED MUSIC Thanks
Old Jan 6, 2008 | 09:58 PM
Elton's Avatar
i would run a better ground wire and go from there
Old Jan 6, 2008 | 10:05 PM
even tho the stock stereo worked perfectly with the same ground?
Old Jan 6, 2008 | 10:06 PM
toytech76's Avatar
Remove the orange black from the red wire. Nothing but another red power wire should be connected to that
Old Jan 6, 2008 | 10:07 PM
toytech76's Avatar
Bad grounds don't cause fuses to blow...
Thats what i was thinking, where should i put that orange/black wire? i need the illumination somehow
Old Jan 6, 2008 | 10:11 PM
toytech76's Avatar
Don't run it to anything. If the stereo doesn't have those wires, it doesn't need it. It will illuminate normally. Check your radio fuses on your harness to make sure you didn't blow them as well. Remove the orange wire and you will be back in business
Old Jan 6, 2008 | 10:18 PM
iceman601's Avatar
Orange wire is only to dim the head unit so it won't be too bright when driving at night. New head units come with two because ones for a postive and one for negative. You will only need to use the postive one if it is too bright for you.
Old Jan 6, 2008 | 10:42 PM
alright! sweet all i did was take out that orange wire and it was good as gold, i love making more work for myself! anyways thanks for helping me out/feel retarded. Appreciate it
Old Jun 18, 2008 | 01:17 PM
birchy's Avatar
*edit* I'll start a new thread.
Old Jun 18, 2008 | 01:38 PM
ozziesironmanoffroad's Avatar
wrap electrical tape over em for added security. i personally like soldering my stuff, but its not for everyone.
MO transplant
Apr 23, 2023 11:58 AM
jasonty
41
Dec 23, 2018 01:00 PM
theking11863
Mar 19, 2016 09:36 PM
TDonkey
Jul 26, 2015 10:14 AM
