Rear defroster not working
Ok, today i had the first time that i have needed to use my defroster since getting my truck. i pressed the defroster button in the center consol by the ECT button and it lit up but after 15+ mins it had yet to do anything back there.
Any ideas as to what the problem could be? As most of you know i had my rear window broken out a few weeks ago. Could that be the problem? The new one has the defroster but i had not tested it before the new window so i am not sure. It looks like the side windows have a defroster as well? If so they were not working either.
I checked all my fuses not to long ago and there were not any bad ones but i am going to check again when it stops raining. so any bright ideas?
Ok, today i had the first time that i have needed to use my defroster since getting my truck. i pressed the button in the center consol by the ECT button and it lit up but after 15+ mins it had yet to do anything back there.
Take the rear panel off your tailgate. There are two wires in there that should be connected to a couple of prongs on the glass near the bottom. Turn the switch on, and check that you have 12V there. If not, work your way back through the system to the switch. Check the fuse again... check the relay... check the output from the switch... etc...
Check the wires that goes up and down with the rear glass.
I think you will find it is broken in two from the fatigue of going up & down.
Solder, retape and you'll be back in business.
Opps, I didn't notice this was a 3rd Gen
My problem was with a 2nd Gen
Yeah it is a 3rd gen. It is also a brand new window so that kind of problem should not be the case. My guess is that it is some kind of no power issue. I am about to go out and check it before it starts raining again.
Ok, i pulled the pannel today and found that it looks like the guy that installed the window must have not hokked it up. The wires were just hanging in there. I checked the wires anyways and thy had 12+ so i think i am good.
I am going to go out later and will try it then.
Thanks for the help!
From: Shelburne, VT previous: Everett, WA; Bellingham, WA
(just a little NW jealousy..)
talk about regional weather! if you don't know where it is, you don't use it, eh? nearly every morning when i go out to do the daily warmup, the rear defrost is getting switched on. you're not an idiot for not knowing where your rear defrost is...kinda.... all i'm trying to say is be grateful with your "sun" and "warm weather"...
I did try it out yesterday and it did indeed work fine!
Insert rant-here:
I have a 2001. My rear defroster has never worked very well compared to other cars/trucks. I purchased it new.....now has only aprox. 50k miles so I know it's never been 'futzed' with.
end-of-rant
end-of-rant
I am from the midwest and my defroster works amazing!!! Since we have had the terrible weather here I have been very thankful that it has worked.
I did find out something very interesting though... I have heated mirrors and I thought that those were only an option on the limiteds? I have no switch for it but it does exhist because it is warm and melts thick ice!!! It comes on with the rear defroster.
So they come on with the rear defroster?
Well I could not believe it so in the cold ice storm while ther was 3 inches of ice on my 4runner and my mirrors already melted I put my cheek up to each mirror and they felt very warm to the touch. That is how I confirmed it.
I have no switch so I guess they come on with the rear defroster. I really dont want to take apart my mirrors to run a DVOM est.
Well i will just flip every switch i have and see what happends when we get some ice. (it will happen at least once, it is not like we are going to get snow!)
