How much memory can XP Pro handle?
Old Dec 6, 2007 | 07:29 PM
BT17R's Avatar
I've read no more than 3 Gb, but that was some time ago, before SP2. I'd like to go with 4 Gb, notebook memory is so cheap right now.
Also, what brand do you recommend for notebooks? New Egg has the best deals on Kingston and Crucial going now. For all I know it's all the same, just relabeled, but see there's a difference in latency and a couple of other things that may matter. Here's a link to the type my laptop uses. TIA...
http://www.newegg.com/Product/Produc...d&Order=RATING
Old Dec 7, 2007 | 07:56 AM
Elton's Avatar
you can run a auto check here http://www.memorygiant.com/ should tell you how much you can use
Old Dec 7, 2007 | 08:08 AM
Turbo4Runner's Avatar
Windows will read up to 4gb memory post SP2. However, not all applications will actually take full advantage of all that memory.
As far as brands, IMO as long as you stay away from the no-name stuff your probably OK. Pretty much all the major brands are good, just get one with the specs you want.
Old Dec 7, 2007 | 09:05 AM
tibbycruiser's Avatar
Xp Pro sp2 Will handle upt to 4gb, if you want more you will need to step up to XP Pro X64 I have up to 64gb on this before.
Old Dec 7, 2007 | 09:09 AM
WI_Mike's Avatar
You can put 4GB in but windows will only recognize 3gb. You might as well get the full 4 gb in case you ever decide to go to a 64 bit operatiing system, and like you said its really cheap right now.
kawazx636
Oct 6, 2021 03:03 PM
kbpickens
Oct 2, 2015 03:37 PM
voiddweller
Oct 2, 2015 07:47 AM
Odin
Sep 26, 2015 06:56 PM
taraf
Sep 25, 2015 02:57 PM
