Wiring 3 pairs of speakers?
I currently have 5 1/4's in the doors and 6x9's in the cargo area. I want to buy some 4" to put in the stock dash mounts. Just wondering if anyone knew what probs I could have by wiring 3 pairs of speakers to a cd player that has wiring for 2 pairs? I was thinking of splicing off the fronts to also run the 4"ers. Being that they are only 4", it shouldn't have much draw at all. I don't want to have to get an amp. Any thoughts?
Thanks, I just did some googling and the consensus is to NOT do it. Most head units I guess cannot handle that extra stress, and even though I was only going to use 4", it could be enough to fry the puny amp in the head unit. So.... I am either going to move up to 6.5" in the doors, or find a tiny amp to power the 6x9's and get some 4" and run those off the extra set from the HU. It's more work/$ than what I wanted to do, but it also seems such a waste to have those empty holes in the dash w/the nice factory grilles. The PO did really bad in cutting into the doors. I would've preferred to get the highest quality 4" for the dash, then some nice 6.5" for the cargo area.
Yea, its a matter of Ohm issues. Most car speakers drawl 4 Ohms and most head units are 4 Ohms per channel. When you wire two 4 Ohm speakers together in parallel (splicing) It cuts the Ohms to 2 Ohms. This can damage HU's and speakers. Make sense?
The best way, as you said, is to add a small amp or get a new HU that goes down to 2 Ohms per channel.
Haha...yeah I know!! Probably pretty expensive! I think finding 8 ohm door speakers is as hard as finding a bridgeable HU. Nah, I think I'm just gona go with 6.5's in the front... or some really nice 5.25's. I don't want to add another amp because I already have 1 for a lil sub box I got. Thanks guys.
Not trying to hijack, but I was thinking of putting some tweeters in the stock rear area above the tailgate for a little bit more treble when hanging out at the back of the truck but I'm unsure of how to wire them in. Any suggestions?
Umm dont bother with 4's in the dash, unless you are doing a 3-way set up (and youre not) it will only kill the sound. theyre only good above 100hz so theyre really not useful. Just fix up teh 6.5's. No point having more than 4 speakers in a car anyways ( i consider components "1" speaker)
Oh, and 8 ohms are easy to find, you just have to know where to look.
a friend of mine wired 8 speakers to a standard aiwa head unit once. after about a week the head unit blew, so he put a new one in, and a few hours later the speakers blew. i wouldnt reccomend going more than 4 speakers.
montanatruck
Feb 26, 2017 07:07 AM
theking11863
Mar 19, 2016 09:36 PM
FS[PacNorWest]: Rear chromoly axle shafts
A2theK
Jan 10, 2016 10:18 AM
Esibnitsud
Jul 30, 2015 08:19 PM
FS[PacNorWest]: Kick panel speaker pods
AkitaDog
Jul 27, 2015 02:38 PM
good luck finding those in car sizes, but it's still a valid suggestion.
