ARB bumper 2nd gen truck how heavy?
Old Oct 21, 2007 | 01:10 AM
paxil4x4's Avatar
Drama Queen/Banned
I should have my ARB bumper in two weeks. I was wondering how heavy they are. Will I be able to man handle it alone?
Old Oct 21, 2007 | 01:22 AM
DeathCougar's Avatar
532.34 pounds.
Naw, not really. But if you have a helper, its much better than trying to do it by yourself. Even the stock bumper is a major PITA the install without a helper.
Old Oct 21, 2007 | 08:01 AM
leebee's Avatar
hmmm, ive r & r'd mine a couple of times without much trouble. biggest pita is the dirt that drops in my eyes while doing up the bolts. a helper would be a good idea, youll need someone to get you a cold beer when youre done!
lee
Old Oct 21, 2007 | 10:00 AM
Belize Off Road Team's Avatar
i'm going to hae to order an ARB soon, cause my bolts are breaking due to bad roads, my bumper is out of alignment, which sucks, but the good thing about removing an early 2nd gen's bumper is it comes apart into 3 different peices! lucky me when i have to remove it!
Old Oct 21, 2007 | 10:12 AM
fastkevman's Avatar
Not exactly an answer to your question but, this might help some.
I installed a Warn winch bumper on my '93 and definitely was glad for some help, it is alot heavier than the original.
Something I was prepared for that some may not be is the Warn bumper has really heavy-duty mounts that wrap around the frame ends and catch stock mounting points, some of which I have no idea what their original intentions are for because there are tapped holes but nothing mounted to them.
Anyways, have on hand some taps, because I needed to tap each hole on my truck to clean them up enough so the hardware went on nice and smooth.
I would assume that TJM and ARB use the same mounting points as the Warn bumper, so if you have 14mm, 12mm, and 10mm taps on hand with some tapping fluid or even just WD-40 it will probably go alot easier.
Just a tip, hope it helps!
Old Oct 21, 2007 | 11:03 AM
Trumpfan's Avatar
Don't try it without help to get bolts started, I installed mine with the help of a engine lift and straps. On an aside I have decranked T-Bars and BJ spacers and I had to re crank my T-Bars because the truck took a stinkbug stance. You're bolting about 110 lbs for the bumper and 60-75lbs for a winch to the front of the truck.
I suspect the truck will want to swap ends a little faster on ice this winter due to the weight transfer characteristics.
*nevermind about the T-Bar stuff I just noticed you've got a 85, nice.*
Old Oct 21, 2007 | 02:16 PM
Tdubbs05's Avatar
i'd say it weighs somewhere between 60 and 80 lbs. with the winch i think it's no more than 150. my front end didn't droop at all with it on if your wondering. then again the bilsteins i have are pretty stiff.
Weidle
Jan 21, 2019 05:39 AM
marcusSRG
Jun 27, 2015 07:13 AM
stunner_runner
Jun 17, 2015 05:35 PM
Robinhood150
Jul 9, 2002 07:54 AM
