Recently installed Boost / vacume gauge. I have some questions???
Old Oct 19, 2007 | 12:56 PM
swerks's Avatar
Question Turbo help ,Recently installed Boost / vacume gauge. I have some questions???
Gauge shows good boost but now Im wondering how to use my vacume
readings? I found charts telling me how to use readings but they say,
not applicable with turbo. My question is what are normal readings for
a stock 22 RET Turbo ?????
Old Oct 19, 2007 | 08:23 PM
Targetnut's Avatar
vacuum readings are relly more of a reference than a specific value. It depends on the cam and valve timing compression and other things as to what you will really see. Basically anything that effects the pumping efficiency will also have an effect on the vacuum readings.
Generally you can expect to see just at or below 20" at idle, and a bit above that during decel. If everything is running normally I'd say to note the readings and use that as a reference to indicate if something is going wrong.
MO transplant
Apr 23, 2023 11:58 AM
Sep 4, 2015 09:27 AM
Coreyr384
Jul 10, 2015 11:13 AM
88runnergomas
Jul 9, 2015 01:12 PM
Avenged
Jul 9, 2015 07:55 AM
