Installing lift need some info.
just wondering if someone who installed a lift on their IFS toyota pickup could answer this question... how do you go about removing the 4 bolts that hold the cross brackets on below the oil pan. im not sure exactly what they are called but there is 4 of them and they hold the A-Arms in place.....
You're most likely talking about the cam eccentric bolts that are used for setting the alignment...
I got three of mine out with a lot of PB blaster and a big hammer. Once I was able to get it to break free and turn, i could tap them out.
The last one though I had to cut out with a 4.5" grinder with a cut off wheel in it. It was frozen solid and rusted in to the bushing. After I did that I had to get a new bolt and bushing to replace what I screwed up...
Good luck. Those can be frustrating.
Yep. Here's the part numbers for the bolt and bushing I replaced. This bushing was the lower control arm, drivers side, to the rear if it matters...
These are OEM from Toyota.
Flying91
45
Apr 11, 2024 04:39 PM
Sep 4, 2015 09:27 AM
coffey50
Jul 28, 2015 10:55 AM
FS[NorAtl]: 05+ tacoma leveling lift front MA
akaphilly
Jul 9, 2015 02:18 PM
