Pre 84 Trucks 1st gen pickups
cut a little too much (axle housing)
Old Aug 22, 2007 | 03:39 PM
HAVOC's Avatar
Exclamation cut a little too much (axle housing)
I torched the brackets off my front and rear diffs today. I made a little groove in the housing where the torque bracket was.
Please tell me that I can have this welded/filled in and then grind it smooth!
It's about 1/8" deep.
Old Aug 22, 2007 | 04:18 PM
MudHippy's Avatar
You can't weld with a torch? Just kiddin', it is a little tricky. Yes, in answer to your question. I wouldn't worry about doing that at all, sounds like the only answer at this stage anyway. It'll hold up just fine.
Old Aug 22, 2007 | 09:33 PM
Elvota's Avatar
You probably should gusset the area as a precaution. If you are already planning on welding on one of those after market upper gussets, you should be okay.
It shouldn't break, but could crack... causing fluids to leak depending on location. If it was me, I'd weld it, smooth it out, gusset it and run it.
Old Aug 22, 2007 | 11:03 PM
HAVOC's Avatar
I plan on a gusset, but I still like to have that area welded up and then I could smooth it out. Just for peice of mind if nothing else.
Old Aug 24, 2007 | 02:44 PM
HAVOC's Avatar
I went to someone I know. He welded them up, grinded it a little and presto, good as new (cost me $20). After I get the axles sandblasted I will see if they need a touchup.
Old Aug 24, 2007 | 02:54 PM
cubuff4runner's Avatar
If you do good welds they are stronger than the steel. You should be ok.
88sasturbotoy
Jan 30, 2026 01:57 PM
deepmarsh
Aug 6, 2015 03:44 AM
Gravel Maker
RuffStuff
Jul 27, 2015 06:53 PM
andrewtexas123
Jul 14, 2015 04:29 AM
Edionne13
Jul 9, 2015 01:59 PM
