fluctuating idle
Old Aug 15, 2007 | 12:23 PM
blueyoda's Avatar
fluctuating idle
Hey guys,
This has been a problem on my runner for som time and I have change a multitude of parts in search of the answer. My truck idles @ 1200 rpm and I cannot turn it down, sometimes after driving, at lights it won't come down past 2000 rpm and I have to put it in 3rd and ride the clutch a it to get it to return to 12-1400. If I have drivin for a good distance and shut the truck off, upon restarting it will idle at 800 rpm until I start driving again. That is it any help would be great.
I have a new o2 sensor, k&N filter, plugs, cap rotor, wires,
Thanks
Old Aug 15, 2007 | 12:37 PM
HAVOC's Avatar
I would clean the IAC (idle air control). Do this off the truck, I think you can mess up your TPS (throttle position sensor) if not. Then set your idle to the proper RPM and then check your timing.
Old Aug 23, 2007 | 03:57 PM
blueyoda's Avatar
thanks, I will do it next week and let you know
Old Sep 7, 2007 | 11:46 AM
blueyoda's Avatar
it turns out it was the spring loaded throtle stablizer, kept sticking, i took it out and the idle is great. Will have a post when my rebuild is done next week
thanks
Blamalam
Mar 12, 2022 07:34 AM
Marsheen
Feb 17, 2016 12:29 PM
GrimWolf
Aug 28, 2015 03:36 AM
noosh
Aug 21, 2015 03:49 AM
Sarcazmo
Aug 15, 2015 08:22 PM
