Throttle body removal
Hello,
Need to clean out the throttle body on my 2000 4runner 3.4L this weekend..
1. Do I need to disconnect the throttle linkages from the throttle body?
3. Got the gaskets I need to replace--do I put any sort of gasket sealant on the gasket itself?
thanks for any help or directions. Jon
You will not have to put any sealer on that gasket. Just put it on and tighten the bolts to the specific torque specs.
As far as disconnecting the linkages it would make it easier to clean if it was all the way unattached.
Hello,
That's exactly what I was planning on doing..clean the throttle body as well as the IAC as it is giving me a rough/low idle problem right now and I'm hoping this will help. I hate to admit it but I actually think I screwed it up myself by trying to clean the throttle body & butterfly without removing it, and a whole bunch of dirty carb cleaner went down the hole in the intake just in front of the butterfly--that's when this rough/low idle problem began.
So just to clarify..i can just loosen the nuts that are on the throttle cables and slide them off their holders and it won't mess up any adjustments?
thank you.Jon
thank you.Jon
thank you.Jon
thank you.Jon
If I recall you can move the throttle linkages by hand so that there's slack in the cables and remove them without unscrewing anything. That's how I did it. Also be careful when unscrewing the IAC from the throttle body. The 4 screws can easily strip.
Just wanted to thank everyone for the great suggestions and advise. Removed the throttle body this weekend and cleaned it out along with the IAC valve assembly. Idle is smoother now and no warm start problems or rough idle..
Throttle body was actually not that dirty as I had previously cleaned it while attached but the IAC and passages were really bad. As mentioned by Saulgoode, the removal process is not that hard--the hardest part for me was removing the water hoses from the body (I reattached with small adjustable hose clamps). Also the 4 small phillips screws that secure the IAC to the body were very tight and can be easily stripped so watch out for that. The only way I could get them out was to use a short 90 degree offset phillips head so it wouldn't strip and that worked well.
thanks again,Jon
thanks again,Jon
montanatruck
Feb 26, 2017 07:07 AM
