Pre 84 Trucks 1st gen pickups
charging problems!!!
Old Jun 16, 2007 | 07:05 PM
fatmatt473's Avatar
i thought the alternator was going out. i got it checked and it was good. the truck isnt charging the battery and wont start. so ihave to jump it. but it only lasts a few minutes and the truck dies. i got a new voltage regulator and battery, it ran for a few days with no charging problems then the charge light came back on and the same problems again???????? i dont know what the issue is with it.
Old Jun 16, 2007 | 07:11 PM
CJM's Avatar
CJM
Obviously something is either draining it or the alternator is indeed bad. I say the alt is bad, did you get a whole dashboard of idiot lights at all in this time, thats your alt dyin.
Old Jun 16, 2007 | 07:16 PM
fatmatt473's Avatar
i thought it was but the people at cutrate said it was good. so i will probably by a new alt. tommorow. they are only 45$ the alternator is dirty and who nows how old it is. the truck is a 79 4x4
Old Jun 17, 2007 | 07:13 AM
Yota Tony's Avatar
Check the fuses too.
I replaced an alt in my Jeep and it turned out to be a fuse.
Old Jun 17, 2007 | 07:46 AM
slacker's Avatar
check your fues links .. directly off the + post on the battery .. there are 2 = a double wire , and a single wire , both with green ends . give em' a tug .. if they break , the wire is burnt .
also check your ground cables .
does sound like the brushes are sticking in the alt though .. been out in the mud since it started ?
80Truck
Oct 12, 2025 07:25 PM
rondogracing
Engine Swaps
16
Aug 24, 2015 03:02 AM
Logz808
Jul 26, 2015 07:09 AM
Jonny246
Jul 24, 2015 12:37 PM
kyletbert
Jul 17, 2015 11:39 AM
