2nd gen Fuel Filter Placement
Co-Founder/Administrator
https://www.yotatech.com/~corey/tech/techpage.htm
Look in the Maintenance section.
That one is for the 3.0, but yours might be down there too.
I'm looking through my Haynes manual.
It says on the 4cyl that the fuel filter is located under the intake manifold and that starter removal may be necessary.
So yeah, it sounds like it will be a PITA to do. Unless you have a problem, you may want to just leave it alone.
Good Luck
Good Luck
