remote start without clutch switch bi-pass!
Old Jan 17, 2007 | 05:38 PM
943kgt's Avatar
well not really you still by pass the switch but you have control over it. this only works if you have the clutch cancel switch. The switch only has accessory power when you turn the key on so your going to have to find out which wire gives you it. for me on my 95 pickup it was a black and yellow wire. Cut this wire and splice in a toggle switch and run it into the fuse box. I used the brake light fuse and wrapped the wire around the fuse on the side that does not have power so it is protected. mount the switch and viola. Now for your manual car to jump when remote starting you some how flip the toggle switch, push your clutch cancel switch and some how forget to double check that you've left it out of gear!
mskalmus
May 28, 2017 07:51 AM
Kalihi,HI
Jul 9, 2015 04:29 PM
bryan34w
Jul 6, 2015 05:53 PM
colinmil
Jul 6, 2015 04:03 PM
karbin
Jul 5, 2015 11:37 PM
