Pre 84 Trucks 1st gen pickups
engine?? swap???
Old Jan 12, 2007 | 01:16 PM
CHRISALLEN_279's Avatar
engine?? swap???
ive got a 78 toy 2wd and was wandring what i would have to change to put a chev 350 in it. or if it would be better and cheaper to build the 20r. and how much power can i get out of the 20r.
Old Jan 12, 2007 | 05:03 PM
skoaq's Avatar
cant get much power of the lil 20rs i went with a new 22r swap and part of me wishes i went with the chevy, what it takes to swap it in there im not sure i never looked at it that closely. i would say try searching im sure theres a write up on this site or maybe search it on google too. its pretty common you will find stuff.
Old Jan 14, 2007 | 11:59 AM
Ditchpig's Avatar
You'll need an adapter for the bellhousing, clutch stuff from the chevy, and more I'm most certainly forgetting. Most people do the 350 V-8 or a 4.3L V6 that is a total gas pig.
Old Jan 14, 2007 | 03:28 PM
toy283's Avatar
I wouldn't run a stock Toyota tranny (especially an L series) behind a V8, even a mild one. Good thing about being 2wd is that there are numerous options for different trannies that will work just fine, a T5 from a Camaro would be my choice but there are others. In any case, a manual tranny would require a bit of fab work on your part (crossmember, etc.) , an auto may or may not.
Old Jan 15, 2007 | 06:09 AM
fourwd1's Avatar
And don't forget suspension. You'll have to beef it up a lot to handle the weight, and there's clearance issues with the oil pan to deal with. And cooling, and clearance issues in the engine compartment.
icentropy
Sep 16, 2020 02:47 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
mskalmus
May 28, 2017 07:51 AM
steve miller
Oct 10, 2015 01:40 AM
coryc85
Sep 9, 2015 06:24 AM
