New Brake swap upgrade for 19831995 Toyota Pickup 2WD front wilwood, 12.2" rotors.
Hey guys,
Just finished designing and machining a new front caliper bracket for the 19831995 Toyota Pickup 2WD. It lets you bolt on either a Wilwood 4-piston or 6-piston caliper using a stock 2018 Lexus IS300 rear rotors thats a 12.2 inch rotor compared to the original 9.7 inch rotor.
The four-piston caliper is Wilwood part 120-13844, and the six-piston option is 120-13435. Both are a huge step up from the stock single-piston setup, and the pads are significantly larger too.
After testing, the four-piston setup clears 15-inch wheels, while the six-piston needs 16-inch wheels. The new rotor mounts on the front of the hub, so the wheel sticks out about 8mm per side.
This has been one of the most requested upgrades Ive gotten over the years, and Im glad its finally done.
If anyone wants to brackets or full kit I've got them up on silverminemotors.com
Looks cool! i'm interested
But i don't see the option for just the bracket on your site?
And does this require longer wheel studs or any other changes to the factory spindle?
