Pre 84 Trucks 1st gen pickups
Tilt Steering Problem
Old 01-18-2018, 01:56 PM
Rusty81Yota4x4's Avatar
Hello!
I have a 1981 Toyota 4x4 that I’ve slowly been restoring. I noticed the tilt/ steering broke loose on me while driving the other day...which now completely rotates. Went ahead and took off the column cover and noticed these two guys must’ve busted; I’m assuming the pins or bolt heads busted? Not sure what size bolt to use or where to look to fix this issue. Thank for yall’s help!
Angle view
Side view
Full tilt view
Old 01-18-2018, 06:43 PM
95yoda's Avatar
I couldn't imagine it being bolted up as it had to swing up and down. On the top pic it does kind of look like a stud of threads is still in there? If so you could take it out and use it to figure the right thread/size.
I've never had my Column off to see inside there.
Old 01-18-2018, 07:32 PM
Ah ok, so remove the excess thread and try to pair it up with something close to that. I came across another pic I snapped and it’s pretty straight forward of what I should do; I guess now I have to figure out to disassemble the steering to get the other bolt reverse drilled out.
Old 01-18-2018, 07:33 PM
Old 01-19-2018, 06:21 AM
95yoda's Avatar
Put some pb blaster on it and put a vice grip on the end and that thing should turn out. It hasn't been exposed to the elements so it might come out without pb. Are the others out or broke off flush? Those might need an ez out
Old 01-19-2018, 09:29 AM
Awesome thank you, I’ll give that a try! Yes the other one is completely flushed.
Old 05-29-2019, 10:49 AM
bpolk's Avatar
For your specific vehicle, you may want to check out diagrams under Transmission & Chassis/Steering Column & Shaft at:
https://toyota-usa.epc-data.com
Old 06-01-2019, 06:48 AM
bpolk's Avatar
Bolts on tilt steering
Took a picture of my ‘81 tilt steering (original):
Attachment bolts on tilt steering assy
Old 06-03-2019, 05:22 AM
bpolk's Avatar
daved5150
05-18-2012 01:36 PM
IVrunner
03-26-2007 05:26 AM
hub_01_69
02-03-2005 11:57 AM
obscurotron
15
09-19-2004 11:50 AM
Quick Reply: Tilt Steering Problem
