Vendors Build-Ups (Build-Up Section) Vendors can showcase customer builds here
toyotafiberglass- fixing floor rust
Old 12-07-2012, 05:18 PM
slacker's Avatar
fixing a cab for a customer ..
Cab is a 2WD cab we got so we have some other mods to do as well .. First is the rusty floors !!
started by cutting everything out
and then some POR 15
curing overnight
Old 12-07-2012, 05:19 PM
slacker's Avatar
built some new pieces , and installed
and inside
Old 12-07-2012, 05:21 PM
slacker's Avatar
finished up the floor
now time to seam seal and epoxy
Old 12-07-2012, 07:10 PM
buckwheat's Avatar
WOW! nice work, I wish I could bring my '80 to you for the floor, mine needs it too! Looking forward to the seeing the finished truck, you guys do great work.
Old 12-08-2012, 03:41 PM
slacker's Avatar
Thanks ..
we are currently working on a replacement cab for the 1st gens . with a few different options .
a partial shell for the "buggies" to a complete replacement for the stock units. 2013 is going to be an exciting year
Old 12-09-2012, 04:54 PM
NickMiller's Avatar
Looking forward to see what 2013 holds! Great work as always!
Old 12-09-2012, 05:04 PM
slacker's Avatar
thanks Nick
Old 12-20-2012, 04:46 PM
slacker's Avatar
well more the just floor repairs
battery tray and area was toast , so cut to repair
new piece made , and welded
and new tray set in place .. not epoxied just yet , just sitting there
also fixed the rear cab area
Old 01-10-2013, 06:45 AM
marcfj-45's Avatar
Originally Posted by slacker
Thanks ..
Do you have more info about that .... i will stop looking in the States for a good cab if you will sell them. Are they complete, we just need to add our dash, seat and everything or do we need partial cab section . Let me know im excited about that!!!!!
Marc.
Old 01-10-2013, 05:00 PM
slacker's Avatar
Were building 3 different options ..
a "shell" for the buggie guys , a cab with no rad support , for the guys with tube fronts , and a cab with rad support complete with even a battery trey .
Floor up to the firewall section and mounts are steel , with a fiber shell epoxied .
we are going to offer a cage as well .. + dash and other goodies .. we are just in the process of building
Old 01-11-2013, 02:22 PM
Lons81's Avatar
Excuse me for being a newbe to rust repair, but what gauge metal did you use for the floors? How did you get the metal to match the stock contours?
I am probably going to replace my rusted battery tray also, so any info on the tray replacement would be a great help.
Been watching you rebuild, some awesome work going on in your shop. Too bad I'm in the lower 48
Old 01-11-2013, 05:30 PM
slacker's Avatar
battery trey we sell http://www.toyotafiberglass.com/truck_12.html is chemical resistant and simply will epoxy into place
steel guage is 20 , and I used my bead roller for the corrragations .. works great for strengthing the panel
Old 01-25-2013, 04:11 PM
slacker's Avatar
well being this is a 2wd cab , there are some mods to fit to a 4wd .
one of them being the front mount . One way is to replace the front crossmember .. probabally the easiest , but I dont have one , and I cant find one , so heres how I'm going to fix it :
some welding , and finishing , and I can check this part off the list
Old 01-30-2013, 04:24 PM
slacker's Avatar
mid mounts made
welded in place and some seam seal
Old 02-12-2013, 05:05 PM
slacker's Avatar
some epoxy
and our NEW battery trey epoxied in ...
we're now done
Old 01-22-2017, 12:55 PM
robbierad's Avatar
very impressive work, well done sir
Old 01-22-2017, 02:44 PM
slacker's Avatar
thanks
Old 02-17-2017, 06:52 PM
Ryall's Avatar
Have you guys made any progress with the full cab options?
Wondering as I'm in a similar (but worse) situation and weighing options aside from my current plan to rebuild the entire floor & rockers and then most of the firewall.
Old 02-18-2017, 04:21 PM
slacker's Avatar
No I haven't .. my shop is so booked up(2.2 years ) , So I have had to put ALL the new stuff on hold .
looking for staff , but it is VERY difficult .
If you have a look in my Trekker build though , I replaced the works , floor , tranny tunnel , rockers .. might give you some ideas
Old 02-18-2017, 04:37 PM
flg8r22's Avatar
I'm still interested in coming to work for ya
20+ years tooling experience and product development.
Quick Reply: toyotafiberglass- fixing floor rust
