GPS & Communication Discussions here pertain to the use and troubleshooting of GPS, CB radio, and amateur radio
Couple of CB questions RE: Power source & antenna
Old Aug 31, 2006 | 09:12 AM
cackalak han's Avatar
I just ordered my CB radio this week, and it should be here today or tomorrow. Since I don't know too much about car electronics, which power source would be the best for the CB? Should I tap into the radio? If someone has a diagram/picture with which wires to tap into, that'd be great.
For the antenna, I think I'm going to get either a 4' whip or firestik and mount it on the front luggage rack. I'm going to try and not drill a hole through it, but rather rig up some sort of a clamp. I'll post pics when I get it done.
I've read good things about Firestik. The Wilson's are nice, but I'm not THAT into CB's to put any more money into it. I think the whip will suffice, though, and I do like the look better with the whip over the Firestik. But if it came down to it, I'd choose performance over aesthetics. Does a Firestik outperform say an antenna from Radio Shack?
Thanks for any input.
Old Aug 31, 2006 | 10:04 AM
SLC97SR5's Avatar
The variable that really changes performance is the area of the ground plane and how well the antenna is tuned to the CB. Any CB/Amateur Radio shop will do this for about 15 bucks and it makes a world of difference in TX/RX. I had a really nice 4' k40 but snapped it while wheeling so I now have a 4' FireStick. I tapped into constant power so I could power the CB w/o the ignition on. Pull off your driver side door sill(long 4 screw plastic piece) and then pull the kick panel and start probing for power. I also like constant power because it seems a little cleaner since voltage is being fed directly to the CB and not split off to anything else.
razorman8669
Jul 12, 2015 12:13 PM
shar
Jul 9, 2015 12:38 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
cyclist231
Jul 7, 2015 12:56 PM
