Vehicle Audio & Home Entertainment Discussions here pertain to vehicle stereo systems and home entertainment systems
your answer to will it fit
Old May 18, 2006 | 09:20 AM
Elton's Avatar
i know some of you are wondering if a stock stereo from a 98 4runner will fit a 91 4runner the answer is yes it will fit perfect after doing a few stereos i have noticed that toyota must use the same style connecters in all there stereos just thought i would let you guys know
Old May 22, 2006 | 05:52 PM
profuse007's Avatar
it depends on the stereo. although toyota utilize a unversal harness, the secondary harness can vary from car to car or stereo to stereo.
Old May 22, 2006 | 07:35 PM
tour4fun's Avatar
I have a 1999 4Runner with the single disk and cassette. Does the Toyota 6 disk CD (from 2000 Camry) fit?
TIA
Old May 22, 2006 | 07:37 PM
Elton's Avatar
im not sure i know my sisters 96 camary had the same style plugs
Old May 23, 2006 | 06:34 AM
Bumpin' Yota's Avatar
ok im going to UL some pics of various toyota plugs. No they are not universal, however the standard toyota double molex is the most common...
Here is the conventional toyota double molex, that was described in Elton's first post. This harness is what's in my own vehicle, and probably about 96% of most toys on the road.
Here is the other plug you might see behind your radio and is pretty darn common; it's the green plug coming out of the top of the box with the cooling fins (that's your OEM amp btw and on the bottom of it you'll find the plugs pictured above - hence why I can say they are on 96% of toys...hehe) Basically with this plug you'd need an amplifier integration harness which the part number is MET 708113 and you'd need a deck with 2 sets of RCA outputs too.
worth of not is that both pics above came from the same vehicle - a '95 toyota 4runner with the 3vze. (A complete dog compared to mine but none the less...hehe) So bypassing an amp in most toys is as easy as unplugging 2 plugs and plugging them into your harness!
Old May 23, 2006 | 06:38 AM
AH64ID's Avatar
Back in college I took componets from a 95 4runenr, and 97 taco, mixed them and put them into a buddies 98 tacoma, it was just plug and play.
suppra87
Jul 15, 2021 05:15 PM
1uzRunner
63
Nov 10, 2018 03:58 PM
choppe777
May 16, 2016 08:00 AM
Daenerysdad
Oct 1, 2015 07:33 PM
bootscootboogie
Sep 5, 2015 05:57 AM
