SaS. 90 4runner. Dana 44 front 14bolt rear
Old May 22, 2011 | 07:40 PM
Countryhick's Avatar
also doing a 3.4 swap. rebuilding motor in process.
gonna use HD 4inch Trail gear springs with 6inch shackles.
gonna be running 39.5+
i want some ideas on springs and what you think i should use maybe even. ill be starting this next weekend on cleaning up axles i just rebuild them with 513 gears lockers F/R
Old May 22, 2011 | 07:48 PM
bigarms23's Avatar
im running 5inch tg front and rear springs and have enough clearence for 39s you made a good choice with 513s shave the 14bolt and chromoly the front axle but eventually the d44 will be your week link if you run 39s
Old May 22, 2011 | 07:50 PM
the 44 isnt to bad with the 39.5's ive ran the hell out of my friends dana 44 and havent had a problem.
but yeah idk if i should do 4inch in front and 5inch in rear or not with a 4runner im debating still because of the sag but if i go hd i dont think they get sag at all. i wanna do 4inch F/R because i have a 2inch body i put on for the 3.4.
Old May 22, 2011 | 08:15 PM
im debating on buying this as a full kit.
Trail gear shock hoops.
4inch HD springs f/r
6inch drop shackles
creeper joint shackle mounts.
high steer from sky manufacturing.
i think thats all i need in my head atleast
Old Feb 28, 2013 | 06:14 PM
bennybigt9's Avatar
I'm in the middle of the same thing...what did you wind up going with?
lledwod
Aug 30, 2016 01:03 PM
jerusry
Oct 19, 2015 05:28 PM
Daneums
Aug 20, 2015 05:36 AM
Nickdigg
Jul 7, 2015 06:04 AM
toyoda8488
Jul 5, 2015 10:18 PM
