Rear 3 link kit on the market!!
This should help some of you guys who don't have the tools or knowhow to link your truck...what's cool is that they have figured out how to do it without relocating the gas tank: http://www.pirate4x4.com/forum/showt...hreadid=203252
The last post says that it's not meant to be a gay ramp champ, but I don't know about you guys, but the whole reason for doing a totally custom rear setup would be for sick amounts of flex for me. What about you?
Chris
Chris
I could be wrong, but I'm thinking that kit is for 1st or 2nd gens, particularly since they were talking about chevy springs. The back end of our 3rd gen flexes okay as it is, not great. I'd slap ona couple of longer shocks, and spend the money on SAS if I was serious about making the 4runner into a true offroader.
Having crazy flex in the back with IFS in the front is like having a Tyrannasaurus Rex for a truck. Tiny little front feet, so if you lean forward too far you can't prevent yourself from falling over....
there is such a thing as "too much" flex. ramp champs are gay, plain and simple. get one in an off camber situation and it will spontaniously flop. one side will just unload, with no weight on it to help you power out of it. this is why revolvers are dumb. you get more droop, but there is no weight on that drooped tire, so you still dont gain any traction. you still want good flex, which i am sure this kit gives great flex, but it is all usable. there is no "wasted" flex.
Originally posted by ravencr
Enlighten me! I know I want very little, and that it's prevented by making the traction bars as parallel to the ground as possible, but what about rear steer?
Chris
Chris
there will be rear steer no matter what, the key is getting it as minimal as possible. using 38" links, i dont think rear steer will be too bad on this kit, but it will exist.
Everyone is so short and too the point on this subject when I'm looking for more details as to how to prevent these things in relation to link location and design. Does anyone have any more detailed input they could provide?
Chris
Chris
i could sit here and type for at least 3 hours trying to explain everything i could think of, OR, i could just do this....
link
this describes speciffically for an oval track, but many of the basics are still the same. also, go to your local library and see if they have any books on chassis engineering, i forget some of the titles, but the are very helpful, and extreamly specific.
you could search pirate, but i think that you would spend more time sifting through the BS than you would actually reading about the suspension.
link
Dude, just search over on pirate and you will learn alot, i know i have. gtanted theres as much BS as good info, keep reading. Check in there frequently and read all the current threads, many are suspention related. I have bee doing most of my reasearch over there. I am getting an 87 4runner, for next to nothing, it aint pretty, but it will become a trail oonly rig. I have been getting design ideas to make an awesome 4runner. THis new kit might be what im looking for too.
Chris, go to PBB. You seem to be on the brink of getting some serious stuff done and that place has the tech for that sort of thing.
I wanted to post this when I saw it so that you could take a look, but I have been away from the computer.
The T-Rex analogy is right on the market. Right now my rear is so soft that it does all it's worth before the front moves, the front is stiff, but that is beside the point.
This kit would be worthless on an IFS rig.
Lots of flex is good, but too much makes the rig unstable.
Only problem with this kit for you is that the third link would be right in your gas tank. In principle though, this is a good solution. When the Solid axle fairy beckons me, this looks like the best rear solution because it will avoid moving more weight to the rear.
I don't like the panhard bar design, you can easily put an upper wishbone, with one side clearing the stock fuel tank, eliminating any side to side movement of the axle assembly. I discussed my 3-link design with the fabricator at Marlin's shop, he agreed it would work, but for streetability the 4-link is more stable. Once I get caught up with my current workload I'll give it more thought and make up a jig to test it all out.
BTW their design won't work on the 3rd generations fuel tank on the wrong side.....
FWIW, that looks like a 5 link: 4 arms and the panhard rod...
one dude in our club has had a 3 link system being built my marlin's shop:
http://marlincrawler.com/double_cab_project.html
funny they listed it as a 4 link... i only count 3...
No, it's got 2 links on the left and 1 link on the right with a panhard bar. The reason it won't work on 3 gens is because of the location of the upper link on the left side. As for trying to reverse the linkage to make it work, don't bother the panhard bar must be mounted with the top mount on the right and lower mount on the left, due to the way the engine torque occurs.
The one at Marlins shop is a 3-link with a very nice anti-sway bar design, I was looking at it when I was up there last week.
What I may do is my 3-link design with a 1 1/4" tubular sway bar for the street. Right now I've got several different ideas, I may just fab several different versions to test.
tubing wont work for a swaybar. swaybars are made from spring steel and are subjected to numerous amounts of twisting force, attempting to use tube will result in bent and or twisted off tubing.
