rag joint delete help.
I need to get rid of the rag joint on my 91 truck, I would like to go to a universal joint style for clearance. I have searched but cant find the exact info im looking for.
I am not sure how many splines and what size my steering gear is, is there a universal fit joint that works? anyone have a part number?
will the pre 82 or so shafts work?
any input is helpful, thanks
if it was me i would source another shaft from the salvage yard and cut off the u joint with a couple inches of shaft. cut off rag joint and weld ujoint in place of the rag joint. might be a little ugly buy cheap and easy and if you can weld good strong too
you are gonna have to weld
http://www.flamingriver.com/index.php/products/c0005
