Looking for a Toyo shop in Parker/Castle Rock
So, the wifey’s 4runner, a white 98 Limited with over 150k on the odometer, has never really had any major work done to it. I’m convinced that it’s living on borrowed time, never had the timing belt/water pump changed, just routine oil changes/tires/brakes. My 4Runner down here in the Islands (a lot harder driving) was leaking oil out those back cam plugs on the rear of the engine, dripping right on to the manifold so I took it to a buddys shop. I bought all the parts-timing belt kit/w idler pullys, water pump, rear cam plugs, front cam seals, crank seal, new spark plugs, valve cover gasket. I need a reputable shop that can do this same job for her, along with a fresh oil change, transmission fluid change, radiator fluid, and not screw it up. (Or rip her off)
Any recommendations for a good reputable shop in the Parker/Castle Rock area?
cheart
33
Aug 11, 2017 07:01 AM
jasonbrink
May 14, 2009 12:29 PM
