Need help with code 42 1990 Toyota 4Runner auto 3.slow
So I had to replace my rear diff and the old one had the hole for the abs sensor and now it was to late to get one just like my oem one and I had replaced it with one that doesn’t have it and now my sensor is zip-tied you guys thing that why I have the code 42 it says it for my speed sensor I am running 35s but not sure what I have to do. Thanks in advance
Abs code 42 is over voltage.
ECU code 42 is VSS, you need to look and see if you have a cable drive speedo or electric sender on the side of the transmission. If it's cable drive you problem is somewhere in the dash between the speedometer and ECU.
