Post Your Tests Here Use this sectin for testing your signature files, and for testing pictures/avatars
link test
Old Oct 5, 2010 | 07:21 AM
swampfox's Avatar
link test
moved below in signature
Old Oct 5, 2010 | 07:30 AM
dropzone's Avatar
Fossilized
when you did the hyperlink you had https://www.yotatech.com/wwwbrian894...osanddiff.html
http://www.brian894x4.com/
correct link is below:
http://www.brian894x4.com/Gearratiosanddiffs.html
Old Oct 5, 2010 | 07:36 AM
swampfox's Avatar
I found that out ,I am trying to learn how to add links and other things .The problem is that i am not very good with computers. Thanks for the help i will try again.
Old Oct 5, 2010 | 07:54 AM
dropzone's Avatar
Fossilized
-copy the link you want
-type out what you want the links to say: Brian's Diff info
-High light that
-click on the hyperlink icon
-you will get a pop up to insert the link, you might need to disable/allow pop up if you have a blocker, paste that in
and you should end up with this:
Brian's Diff Info
80Truck
Oct 12, 2025 07:25 PM
bobjohnson2121
Aug 28, 2015 04:02 AM
Dee Draper
Aug 23, 2015 11:54 PM
JUICE222
Aug 21, 2015 05:16 PM
JAmdor3
Aug 11, 2015 10:53 AM
