89 4Runner 22re won’t start
I’m new to this site and thankful for any help. Thought the fuel pump was bad. Installed new pump has pressure off the fitting at the tank and at the cold start injector banjo fitting. Has spark at #1 spark plug and coil wire @ distributor cap. When I try to get a code the light on the dash keeps flashing I stopped at 200 flashes it also stops cranking even though the key is in start mode after it has turned over a few times. I’ve checked fuses and a relay still no start. ECM possibly? Thank you for any advice or what to check.
Thank you first off. I hadn’t even thought of the injectors. Would they all fail at once and is the fuel pressure regulator also failing. How do I test the injectors without being able to start turns over fine but not start. Lots of questions here . Very much appreciate your help and response.
