Post Your Tests Here Use this sectin for testing your signature files, and for testing pictures/avatars
06 tacoma 2.7 crank no start
Old Jan 31, 2023 | 09:43 AM
Chris Johnson's Avatar
06 tacoma cranks but doesnt start when cold. pulled the vaccum line off the throttle body and sprayed starting fluid and it start fine and continues to start fine as long as it is warm. is there a cold start injector i could be missing? what else could it be? hooked up a scan tool and coolant temp sensor reads ambient temp.
Old Feb 5, 2023 | 06:11 AM
jeremy harp's Avatar
did you check the fuses ?
