Vendor Advertising Vendor's, use this area to alert members to your OEM & Aftermarket Toyota parts
Get 10% Off Discount on Westin Pro-e Electric Running Boards for 2024 4Runner
Old Mar 18, 2025 | 01:34 PM
carid's Avatar
Premium Sponsor
Your 2020-2024 Toyota 4Runner is built for adventure, engineered to conquer remote trails and extreme environments—it’s in its DNA. However, upgrading your SUV with larger, more aggressive off-road tires and a lift kit can make cabin entry and exit more challenging, especially for the passengers. That’s where Westin’s all-new Pro-e Cab Length Black Electric Running Boards come in.
Designed specifically for your 4Runner, they offer a 6-inch-wide, aircraft-grade aluminum stepping surface for enhanced safety and convenience. With a robust 300-lb. weight capacity per side, these running boards provide a sturdy and reliable step while complementing the rugged look of your SUV. Each Pro-e running board has two IP68-rated waterproof motors per side, ensuring smooth operation in mud, rain, snow, and extreme temperatures. They extend automatically when the doors open and retract when closed, maintaining your vehicle’s ground clearance for off-road performance.
For added safety, integrated LED lights illuminate the step area, enhancing visibility in low-light conditions. When retracted, the boards fit snugly against the body, protecting rocker panels from scratches, dirt, and road debris. Additionally, these running boards provide an extra level of functionality, they act as a stable step for accessing roof-mounted cargo, making it easier to load and unload gear for your next adventure.
WestinŽ 29-23835 - Pro-e Black Electric Running Boards
Notes:
Mounting brackets Included.
Features:
  • Fast and easy installation – no drilling required;
  • Automatically deploys when any door opens then retracts when doors are closed;
  • 2 waterproof IP68 rated motors per side;
  • Included LED lights illuminate step surface;
  • Sleek and snug up against body when closed while protecting vehicle rocker panels from potential damage;
  • 6" wide durable aluminum running boards;
  • 600 lbs. weight capacity (300 lbs. per side);
  • Corrosion-resistant aluminum boards;
  • Hardware and mounting brackets included;
  • Available in black powder coat finish;
Designed for a hassle-free, bolt-on installation, the Pro-e running boards come with all the necessary mounting brackets and hardware, ensuring a perfect fit for your 4Runner without the need for modifications.
Old Mar 18, 2025 | 01:35 PM
carid's Avatar
Premium Sponsor
From March 13, 2025, to March 25, 2025, take advantage of our exclusive online deal on premium Westin Pro-e Cab Length Black Electric Running Boards and save up to 10% off!
Special Offer Available Only on Our Website!
Don’t miss out, order now and upgrade your ride with advanced style, convenience, and ultimate protection!
If you want to learn more about Westin Automotive and explore the complete range of options suitable for your application, please click the link below:
https://www.carid.com/westin-automotive/
Whether you're after an aggressive styling, comfort-enhancing solution, or maximum versatility, there's always an option for you.
carid
Jan 8, 2015 02:26 AM
nuttgobler88
Aug 31, 2009 09:29 PM
rdang
30
Jan 8, 2008 06:59 AM
Toy ta that could
20
Jun 11, 2006 04:39 PM
Masato
10
Jan 7, 2005 04:38 PM
