Lift questions
Old Oct 22, 2003 | 08:20 PM
4Runnincolorado's Avatar
Lift questions
Hello, i just got a 97 4runner sr5. im looking to lift it and give it some good off road capabilitys. id like to see it with 33s but i dont know where to start. Ive been told that a 4' OME is good but i have also heard that you dont need 4 inches of lift to squeeze 33s. Also with the rear locker, mine did not come with one but i am going to put one on, not sure weather or not to go with the factory electric or do somthing like ARB. Im still learning so if anybody could let me know whats recomended, i would apreciate it.
Old Oct 22, 2003 | 08:32 PM
Albuquerque Jim's Avatar
Seriously,
Use the search button at the top of the page. I'm not being a jerk, there is just soooo much info here, you'll see.
Old Oct 23, 2003 | 06:44 AM
data's Avatar
Senior Member
If you go with any type of suspension, go with SAW's in the front and the OME rear setup. This will yeild somewhere around 2 1/2" of lift. That is enough to fit 285/75/16's. That is about the highest amout of lift you can go without beating up the cv's too much. As for the locker, go with arb if you can afford it.
Old Oct 23, 2003 | 01:32 PM
SAWs?
what exsactly is SAWs?, like i said i new at this. I know OME is old man, but im not exsactly sure what saws is. are there any other companys that are recomendable? or do you all just recomend those two?
Old Oct 23, 2003 | 04:16 PM
PoBoy's Avatar
see light flashing above ^^^?? Click it. Mike at Extreme Offroad can help ya out.
Old Oct 30, 2003 | 04:25 AM
AznSky's Avatar
Fronts:
SAWS = Sway-A-Way
They make an adjustable front coil over setup. That way if you ever get a steel bumper (ARB, TJM etc.) or a supercharger, you can adjust your fronts to be level with the rear because it will start to sag.
Also Downey makes an adjustable front coil over as well. Same thing as Sway-A-Way.
Rear:
OME = Old Man Emu
Makes rear shocks and coils
Downey also has rear coils that will provide you ith 2.5 " lift most likely
Bilstein also makes rear shocks
All you will need is 2.5 " to wheel. If you truelly wanna go higher then be my guest. You will probably have to get a manual hub conversion in the front though.
I went with a OME/OME setup (OME shocks and coils in front and rear). Just because I'm not a hardcore wheeler, and I don't plan on installing any steel bumper or winch up in front.
Instead of paying around 900 bucks for a lift, I only payed 650.
Happy hunting.
Oh yea, you'll want to buy from this guy www.xtremeoff-road.com
Excellent man to deal with
Old Oct 30, 2003 | 06:19 AM
waskillywabbit's Avatar
Re: Lift questions
Some light reading and all you need to know!
http://fastq.com/~sschaefer/recommend.html
Hope this clears away some confusion!
Flying91
45
Apr 11, 2024 04:39 PM
Sep 4, 2015 09:27 AM
4Runnin2000
Jul 29, 2015 06:09 PM
coffey50
Jul 28, 2015 10:55 AM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
