2nd Gen 4Runner Rear Control Arm "Lift" Bracket?
Old May 24, 2019 | 11:55 AM
yota_terror's Avatar
I installed LC coils on my 1990 4runner which resulted in about 3.5 - 4" of lift. It looks to me as if the passenger side rear control arm will end up hitting the gas tank when this thing starts flexing.
Where are people buying these "lift" brackets?
Old May 24, 2019 | 08:10 PM
Co_94_PU's Avatar
I think you have posted the wrong image?
Your control arm (length) geometry doesn't change such that they no longer hold the axel centered on the frame with this kind of lift kit. You get the same travel for the most part (left/right) up and down, but added a little bit of stress (moment arm) on the bushing which could end up changing it t such that your bushings do not constrain the left right movement of the rear end of the brace.
This is what bump stops are for, they mechanically set a limit of movement.
But again your picture isn't very clear about your concern. Jack it up flex it out and see what is what.
Old Sep 27, 2021 | 08:34 PM
Cammyh97's Avatar
I don’t think he posted the wrong picture at all and he is pretty detailed about what he is saying
yea the control arm will hit the fuel tank with that much lift while flexing. I haven’t seen the brackets before but wouldn’t be hard to make them
the easiest way it to purchase extended upper control arms and one will come slightly bent to allow it to miss the fuel tank. While at it it’s best to get lower ones too to correct pinion angle and will push the axle back to where it should be.
extended arms will make it “flex” much better and put less stress on everything
btu44
Feb 7, 2016 06:18 PM
irvingdizzle
Feb 27, 2010 07:23 AM
Rusty Davis
Feb 23, 2007 11:39 AM
ravencr
Feb 3, 2004 05:14 PM
