Early Land Cruisers All solid front axles and Land Cruiser series - 25, 40, 45, 55, 60, 62, and 80
1991 fj80 front end squeak while driving.
Old Mar 3, 2010 | 08:34 PM
pkorrupted's Avatar
I just bought a 1991 Land Cruiser and when I drive over 10mph the front end squeaks accordingly with the speed of the vehicle. The faster I go the faster the squeak. This weekend im going to replace the shocks and sway bar bushings and when im under the truck I dont know where to look to solve the squeaking. Its solid axles front and rear. It sounds like a rubber on steel squeak. Thanks
Old Mar 4, 2010 | 06:00 AM
Ardent's Avatar
Sounds like it's time to do your front axle service. It could be your birfs if they're getting dry, or any number of other things. Check out IH8MUD.com under 80 series tech for info on the service.
Old Mar 4, 2010 | 08:29 AM
pkorrupted's Avatar
Is there a way to just check/fill the hub assembly? the knuckle is not leaking and the diff fluid is full. Is there a spot on the hub assembly to put more moly grease? Is there a plug where the abs sensor is on the newer model axles?
Old Mar 4, 2010 | 10:09 AM
Ardent's Avatar
There's a plug on the forward-top part of the knuckle with a square head. You can check the grease there and add if necessary. make sure to use moly grease only in knuckle.
Old Mar 4, 2010 | 07:13 PM
pkorrupted's Avatar
Thanks alot, im going to tear into the truck in the morning and hopefully that is all the queaking sound is. I made sure to get moly grease and a grease gun to inject the grease in the hole with.
Old Mar 9, 2010 | 08:11 PM
FlyingLow's Avatar
I don't think it will be the grease in your knuckles. If so yo will need more than just grease...
88sasturbotoy
Jan 30, 2026 01:57 PM
Flying91
45
Apr 11, 2024 04:39 PM
Colington
Mar 8, 2020 09:51 AM
jasonty
41
Dec 23, 2018 01:00 PM
Daneums
Aug 20, 2015 05:36 AM
