Prerunner & All 2WD Rigs Discussions pertaining to non 4WD rigs
How to fix bowed/bent bed?
Old Feb 25, 2016 | 10:13 AM
mistershmi's Avatar
Has anyone had this happen?
My 93 2wd bed is bowed out so that its rubbing up against the cab ( not badly, but its close enough that when theres flex it does rub)
My guess is when I was hauling gravel or something the load shifted and pushed that front bed wall out and made it bubble out like that.
I'd be interested to see if anyone else has had this problem and how they fixed it. Ill try to add photos after work.
Old Feb 25, 2016 | 10:23 AM
Terrys87's Avatar
If you mean the header part of the bed, I would just give it a good tug or even a come along on it with some pulling on it to where it needs to be. For the sheet metal part, I have just used a hammer and dolly to get it bent back to shape as close a possible.
The top part of the header is bolted in but the bottom is spot welded, if you want to replace it from another bed.
tomanator
Feb 21, 2016 02:22 AM
kauaiaxel
Feb 16, 2016 12:37 PM
MudWaspSR5
Feb 9, 2016 11:28 AM
Scotto6591
Feb 6, 2016 09:12 AM
Tyler Zemlicka
Feb 4, 2016 11:18 PM
