1998 4Runner sputtering
Old Feb 6, 2013 | 03:47 PM
TangoDown's Avatar
I just had a tune up on my 98 4runner 3.4L 2wd and replaced a coil but it's still sputtering and misfiring. Any suggestions? Thanks
Old Feb 6, 2013 | 05:57 PM
stockwell45's Avatar
Any CEL?
Old Feb 6, 2013 | 06:04 PM
TangoDown's Avatar
The CEL had been on for an O2 sensor but it hasn't had a CEL since the tune up yesterday. It is sputtering intermittently.
Old Feb 11, 2013 | 01:34 PM
mastacox's Avatar
Sounds like you'd better try replacing your o2 sensor, it could be your engine is running either too rich or too lean due to a sensor issue.
Old Mar 22, 2013 | 11:45 PM
griffin1ets's Avatar
Was it o2?
Old Jun 19, 2013 | 06:27 PM
fhalperformance's Avatar
I would start with the oxygen sensor. Are you using the oem type spark plugs? I have a similar issue on my build. It ran alot better after I put the right spark plugs in. Could be coil, spark plug type, spark plug wire make, injector, engine ground, head gasket issue.
Flying91
45
Apr 11, 2024 04:39 PM
Charecter1
Nov 6, 2023 10:08 AM
icentropy
Sep 16, 2020 02:47 PM
the1998sr5
15
Jul 14, 2020 08:35 PM
BeMiceElf
Oct 10, 2015 09:40 PM
